Noisy water pump (1 Viewer)
colleen murphy
47
11
shrewsbury
Celtic Rambler 5th Wheel
2 years
We have recently purchased a Celtic Rambler and find the water pump to be very noisy. Any advice out there please?
Nov 2, 2008
461
377
Lincolnshire
PVC, S&L Iveco
45 years
We will need more information. What make and model pump, what sort of noise and has it just started or same when you got the camper.
Jun 30, 2010
7,927
27,281
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Don't think you'll stop the noise altogether, but I quietened it down a bit by cutting out, Washers for want of a word, from an old wet suit and adding them under the 4 feet .
43,423
50,186
As Rangi said but use a sheet of heavy foam a little larger than the pump feet.
Fix the pump to the foam using small nuts, bolts and large flat washers from the foam side upwards ensuring the bolts can't touch the floor.
Screw the foam pad to the floor with washers to stop the screws pulling through the foam.
The pump itself is then fully isolated from the floor and pump vibrations can't be transfer to the sound board (floor)
Next, check all pipework in the vicinity of the pump is securely clipped or is not touching the floor or furniture which will also act as a sound board.
After all that the only thing you should hear is the clicking of the pump and the splash of water from the taps.
