No power to PCB switch on toilet switch - Flash 04 2014 (1 Viewer)
May 25, 2022
28
14
Rothley, UK
Chausson Flash 04
Since 2019
Hi folks
Just back from a trip and once home the blue switch in the toilet has stopped working. There is no fuse in the outside toilet compartment, and I cannot find where the power source is that feeds the PCB switch. i.e. there is no power reaching the switch. The main water pump is working fine for the sink and shower.
Anyone got any ideas or can help me please ?
Many thanks in anticipation !
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Maybe if you said what MoHo you had and toilet model info would be more related
J
May 25, 2022
28
14
Rothley, UK
Chausson Flash 04
Since 2019
Hi Geo. It was in the title of the thread.
It is a Chausson Flash 04 2014
Many thanks for asking.
Dec 6, 2011
11,613
25,497
South Wales
Coach built Adria
Hi and welcome.
Often the flush power supply is piggy backed on another ancillary.
So I would check them all as a starter point.
J
May 25, 2022
28
14
Rothley, UK
Chausson Flash 04
Since 2019
Some photos of our Thetford toilet
May 29, 2013
2,607
19,310
Tyneside
Chausson best of Flash 10
Several years now
The toilet is powered from the lighting circuit. Are all your lights working?
Dec 12, 2010
5,426
21,660
Cumbria
since 2011
If you can satisfactorily rule out a fuse issue, there's a tiny circuit board behind the push button, if you carefully peel the complete sticker off the flush panel, it gives you access to it, they are known for failing. A new board is around the £15 mark.
J
May 25, 2022
28
14
Rothley, UK
Chausson Flash 04
Since 2019
Thanks Phil. I'll take a look.
Hi Phil. Turns out that the 'lighting switch' on the main control panel inside has to be 'on' in order for the toilet flush to work ! How daft is that ! Thanks for your help.
J
May 25, 2022
28
14
Rothley, UK
Chausson Flash 04
Since 2019
Thanks - yes. Turns out that the 'lighting switch' on the main control panel inside has to be 'on' in order for the toilet flush to work !
J
May 25, 2022
28
14
Rothley, UK
Chausson Flash 04
Since 2019
May 29, 2013
2,607
19,310
Tyneside
Several years now
Yes, that's what I was sort of pointing you to.
The lighting circuit powers the solenoid for the toilet, but also needs the pump on to pump water thro the solenoid.
