Niesmann+Bischoff old Brochures (1 Viewer)
chenderson1965
327
274
Nottingham
N+B Arto 79R A Class
10 years with hires, Newbie owner
Hi all. I’m looking around to buy a spare wheel and tyre for my 2012 Arto 79R before I take delivery. Can anyone tell me the spec of the wheels?
Chris
funflair
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Hi Chris
If you take off whatever wheel trim there is you should find a code that tells you the spec of the wheels, just quote this and a wheel person should think you know what your are talking about.
You could try a “wanted” add here on Fun as some people take off steel wheels to fit alloys.
Martin
chenderson1965
327
274
Nottingham
Hi Chris
Martin
If I had access to the vehicle then I’d do that. I don’t get it for another 2 weeks though so was hoping it might be a standard size.
funflair
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Most likely is but may/will depend on if it’s a light or heavy chassis so 15” or 16” I am not up on Arto so wouldn’t guess in case you bill me for the mistake? jongood should have a better idea than me.
Martin
Jun 10, 2010
8,580
20,358
Shrewsbury (sometimes)
N&B Clou Liner MAN
It will be the Maxi chassis so 6 x 16 130pcd and if you really want I can sell you the genuine article as Ive changed mine to Alloys a couple of years ago. £50 bare rim or £75 with an OK for a spare tyre, collect from Shrewsbury anytime to suit yourself.
Jon
chenderson1965
327
274
Nottingham
Thanks Jon. That sounds great (with tyre ideally as long as it’s not too old (it’ll probably sit in my garage for years before it gets used!).
Collection is an issue though as I’m in Nottingham. If you can give me an idea of six\ze and weight, I can look into sending a courier for it?
Oct 12, 2009
10,760
23,839
A Class N+B Arto 69GL
Since 2009
I am also one of the N&B group and can vouch that although small they are knowlwledgable and helpful.
There is a UK owners club hosted on here
It is not very active - because we do not have many problems with them - which says a lot:D
But if one has a problem one of the lads will be along.
Geoff
Jul 20, 2022
53
25
just looking b514
Just took hold of a 1999 flair,
Unreal build quality In fairness,cab a bit faded compared to body,as fibreglass obviously compared to alum body,
Anybody else have this and will it buff up ,
And what would I pay for alloys for it approx,
Regards
Mick
funflair
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Regards
Mick
Personally wouldn't bother with alloys as some nice stainless trims look the biz and last forever unlike alloys, build quality (y)what chassis is it on?
Yes the fibreglass will buff but will need a polishing machine if it has been neglected as it will be hard work by hand, if you have not machine polished before you need to be careful and keep it moving and keep it cool.
Jul 20, 2022
53
25
just looking b514
Here’s photo of it
funflair
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Geoff
I will just add to this that the "Owners club" is closed to new members, possibly as Geoff suggests there are so few problems people don't need to ask questions ;)
funflair
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Here’s photo of it
Nice (y) Looks like the bonnet has possibly been painted at some time and with the stickers on possibly not much you can do with that other than a light cut and polish by hand I would say, not much to worry about on these old girls but check that the roof joint to the cab front is OK, they usually have a tape over the joint and depending what it is it may need renewing.
Jul 20, 2022
53
25
just looking b514
Your right about bonnet,
Previous owner damaged it so got it re painted,
But obviously sticks out now like a sore thumb,
Will see can I cut and polish the rest of front cab,if not a re spray I presume,
Might go different colour with cab altogether,
funflair
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Somebody did a Clou liner blue front and back and it looked errr shall we say different, I would keep it as close to standard as possible but maybe i'm boring ;)
Jul 20, 2022
53
25
just looking b514
It’s on a fiat 2.8 with only 73000 genuine miles and timing belt and water pump done at 69k,
Drives along at 60 no bother on motor way,
It’s weighted at 3850 so I have to go off and get test done to be able to drive it here unfort,
Will it do 28 mpg if driven right !!!
funflair
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Sorry don't really know what it will do to the gallon but I imagine 28 would be close ;)
Jul 20, 2022
53
25
just looking b514
You are right about alloys,steel is one’s on it painted black,will re do them ,
Could do with Manuel in English,
As just trying to figure out how all works,
Can’t find it on line anywhere,
Got a brochure on n the alde heating system ok,
It also has a diesel blow heated fitted,
Got that working ok,
Can’t see my self using the alde as if that cold I should not be away !!
funflair
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Does the diesel heat the water? the Alde does (y)
Jul 20, 2022
53
25
just looking b514
Yes ,
My brother got the alde to heat the water ,
He thinks the alde heating system has been drained of water and liquid that they use ,
That’s why previous owner who has passed RIP put in the diesel heater we think,
funflair
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Yes ,
Would have been easier to just refill the Alde, maybe there is an issue with it, don't forget it must have Glycol fluid in before you try to heat water.
Jul 20, 2022
53
25
just looking b514
Thanks for that ,
Really appreciate your time and experience,
Will get my brother to check it out fully,
Thanks again
