Need help with missing top of rear brake light housing on Swift Kontiki 645 (1 Viewer)
JayVee22
5
Swift Kontiki 645
Hello everyone
I recently purchased an older Swift Kontiki 645 based on a Fiat Ducato 2004 chassis. All good so far. However, at the weekend I went up on to the roof to remove some debris and noticed a horrific mess that is (or should be) my rear brake light housing. That is to say, the rear brake light exists (and works) and looks fine from ground level. But from the roof level, the top of the housing is missing. I have tried and failed to find a replacement top and now wonder what in fact should be there, as every link I find just gives me the red plastic cover/light itself, nothing for the top. Can anyone help point me in the right direction please? Photos attached (I know, right?).
Many thanks
Jackie
Two on Tour
10,430
51,990
Elddis Autoquest 175
Since 2010
J
JayVee22
5
Swift Kontiki 645
I may well have to - but I'm not "handy" on things like that so would prefer to fit something that's designed for the space if possible. :)
Two on Tour
10,430
51,990
Since 2010
Plasticard is easy to cut with scissors and if you need to curve the rear edge to the stoplight, then warming it with a hairdryer will soften plasticard. (y)
J
JayVee22
5
Swift Kontiki 645
In that case you will need to buy a complete new light assembly and fit it.
Thanks Lenny HB. That is what I'm struggling to find though. I can find the front light fitting, but not what should be on the top and have no idea what that might look like.
J
JayVee22
5
Swift Kontiki 645
Thank you. I will keep that in mind as an option if I can't find the right part. :)
Nov 5, 2013
3,136
98,592
Shropshire
Carthago chic e-line
Since 2013
These high level brake lights on Kontikis are notorious for letting the water in so the top cover has to be really well sealed,but needs to be removed to change the brake light so it has probably been broken! It will be a Swift part so I'd be having a word with the people where you had the van from.
J
JayVee22
5
Swift Kontiki 645
Thanks Richard. It doesn't appear to be leaking luckily. It was a private sale and of course not noticeable from ground level so I didn't spot that. I'll refer to Swift and see what they say. A picture of what it should look like would help, but I can't even find that.
Lenny HB
54,019
152,287
On the coast in West Sussex
Hymer B678 DL
You will probably have to order a complete lamp from a Swith dealer don't be surprised if it empties your wallet, Motorhome spares tend to be ridiculous prices.
Worth looking at Hella and Jokon parts as the two of them supply most road lighting for Motorhomes.
Nov 5, 2013
3,136
98,592
Shropshire
Since 2013
Have a word with https://www.olearymotorhomes.co.uk/index.asp?function=SEARCH they buy up old parts stock! or the parts chap at Brownhills is usually helpfull.
