N&B Arto headlight tweeks for driving in Europe (1 Viewer)
Mar 22, 2023
592
1,677
New Forest, United Kingdom
N+B Arto 74C
Going to be driving the Arto in Europe, is there a magic way to tweek the dipping of the headlights so as not to cause a dazzle hazard?
Or do I have to resort to bits of sticky tape like the old days?
JockandRita
11,494
150,426
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Which prime mover and year might bring forth some answers for you.
Our 2006 Iveco Daily based Flair has a dash control, which allows me to raise or lower the beam, but to change from a left dip to a right dip, more involvement is required at the headlamp end of things. :(
Cheers,
Jock. :)
M
Mar 22, 2023
592
1,677
N+B Arto 74C
Our Iveco Daily based Flair has a dash control which allows me to raise or lower the beam, but to change from a left dip to a right dip, more involvement is required at the headlamp end of things. ;)
Cheers,
Jock. :)
Stupid me.
2007 Arto (with the vertical stacked headlights) Fiat Ducato X250
JockandRita
11,494
150,426
Lincs/Cambs border
N+B Flair 8000i
Stupid me.
I am sure that if you remove the stack covers, you should be able to access the beam adjustment.
Hella lamps are usually beam adjustable with some easier than others.
Good luck sorting them out, but you may have to resort to just lowering the beam, if you can't adjust it easily.
How much driving in the dark will you be doing abroad? ;)
Cheers,
Jock. :)
M
Mar 22, 2023
592
1,677
N+B Arto 74C
Cheers,
Jock. :)
Jock to be fair not much night time driving, we are going to the N&B factory open day this weekend. so travelling in daylight on Friday and likely doing most of the return journey on Monday morning, it is just Sunday evening as I think we get thrown out late on Sunday afternoon.
funflair
19,463
30,775
Guisborough
MORELO palace
since 2012
You used to be able to stay till Monday or even later I think and some used to turn up a week early but the field that we always used is now covered in solar panels so things may well have changed, enjoy the weekend though and Saturday night is usually brilliant, certainly is if "TOPSIS" are the band.
And re your lights, I am not sure that the covers come off on the Arto and I think there is not the room behind to get in and turn the units that there is with the Flair so you may be best just adjusting them right down or resorting to sticky tape just in case, jongood should know more than me.
M
Mar 22, 2023
592
1,677
N+B Arto 74C
The Saturday evening band are MĆ¼nchner Zwietracht, looks like fun.
Do you mean the front covers, the silver mould trim pieces as in the photo?
funflair
19,463
30,775
Guisborough
MORELO palace
since 2012
Don't know them, seen TOPSIS there a few times, yes the covers around the lights, on the Flair these come off and it's easy to remove the light units to alter them rather than trying to do it upside down with you head stuck through the bonnet gap.
M
Mar 22, 2023
592
1,677
N+B Arto 74C
I will go and have a look, we have a power cut at the moment but I am back feeding the house from the Honda EU20 !!
Jun 10, 2010
8,579
20,356
Shrewsbury (sometimes)
N&B Clou Liner MAN
NO he doesnt.
You get at them from behind. First identify which one does the dip beam, then have a look on the back and you will see 2 pk screws in slots and one with another hole next to it. The idea is to loosen the screws ( preferably with a magnetic catch under it) so you can turn the lamp through approx 20 degrees. I usually just alter the left hand one so they both dip to the centre, my logic being that its one less to change back for mot and they re like candles anyway so it makes little difference to the driving experience.
Edit to add that its not recommended to put beam benders on as they can attack the surface of the lamp.
M
Mar 22, 2023
592
1,677
N+B Arto 74C
NO he doesnt.
Nov 26, 2014
1,509
6,719
Never on the wrong road ......
since 2014, before that 20 years of boating & caravanning
Just to add to the post by jongood there are three screws if they are the same units as my 2014 Arto,the top one needs removing fully whilst the side ones you loosen until you can pull the rear body away from the lens, and then you can rotate it on the slotted grooves to the opposite position whilst watching the headlight beam against a wall to ensure you've turned it the right way (might already be on left hand, unless you've checked) as it's a bit of a faff, so someone might have previously done it & left it šŸ¤£
Alb
