multimeter useage help (2 Viewers)
Welsh girl
3,658
3,036
Globecar
Ok. I bought one of these to test our leisure battery. Can you explain how to use it please? The instruction leaflet is double Dutch to me.
43,367
49,722
If you simply want to check the battery voltage then set the meter to DC volts, probably 20vdc on the scale/dial.
Put the red wire to the battery positive (+)
Put the black wire to the battery negative (-)
The reading on the screen is your actual battery voltage.
12.6v/12.7v volts is fully charged.....12.0v is fully discharged.
If you get the red and black wires the wrong way round dont worry....the screen will show a - symbol before or after the numbers.
Its still the same reading only negative.
43,367
49,722
Before taking any measurements, zero the scale using the white screw below the needle.
Turn it very slowly until the needle lines up on the zero's on the scale.
A little off and the results could be incorrect.
43,367
49,722
With that type meter ignore my comment about connecting the wires the wrong way.....they MUST go red to positive, black to negative or the needle will try to swing the wrong way.
2,392
10,426
sorry to say, but with an analogue meter of that quality and on a 0-50 vdc scale, it won't be very accurate, it will also be difficult to read accurately.
If you want to learn how to use a meter, and not just for battery voltage, then my advice is to buy a reasonably priced digital multimeter from the likes of Maplins .. from as little as £20
easy to use and easy to read..
MicknPat
614
3,606
Touring UK
39ft American A class RV
Since Oct 2007
2,392
10,426
Like most things in life you get what you pay for David. It doesn't say on the info what the % accuracy is.. so presumably it's not great..
If it's only for using once in a while to test the battery, then it will do the job... it's better than a cheap analogue
If you are going to use a lot I would buy something a bit better .. look for % accuracy..
an example is the Maplins one in my link that gives DCV accuracy as +/- 0.5%
You can of course go to the other extreme and buy a pro meter like a Fluke, but they are over £100
Welsh girl
Welsh girl
3,658
3,036
Globecar
For an accurate reading you need to view the needle such that it is covering it's own reflection in the mirror at the bottom. (PARALLAX ERROR)
The yellow scale on the left is DC volts and the most appropriate on your meter is 50
it is only for occasional use. These are the instructions.
We cant make head nor tail of them
Mar 23, 2012
9,582
32,236
sleights
c class
Quite right but from the original post I thought within 5% would be fine!! I'm a bit of a rough and ready DIY bloke and it would be well worth the extra if your'e using it a lot but for a quick check on the battery volts would probably be more than up to it and there is a tenner towards the battery if you need it :). Our local (not part of a big chain) car spares place would check it for you foe free (and they are honest) just don't try one of the chains where the staff are on a target:(
David
May 29, 2013
2,610
19,361
Tyneside
Chausson best of Flash 10
Several years now
Just a point about the multi meters above and others of the same types. Even if it has a 240v range it is NOT advisable to use these meters to check mains voltages, it is a safety issue. You really want a martindale tester for mains work, much safer.
Sep 24, 2013
1,317
753
Norwich
Carthago A class
Since 2014
Some multimeters have three sockets (as the screwfix one). The left hand one is for measuring amps (current). The right hand one for volts (centre is negative -common). Make sure you use the correct one!
Apr 2, 2014
285
296
Lancashire
Since 2003
Evidence please.
11,851
14,093
This is the problem when they use google translate on the original Chinese. Do not read these instructions, you will go mad :mad::mad:
23,841
72,711
Jim, just recently been on a school site and junked more than 60% of all their fluke digi meters.. All less than 2 years old and all miles out.. Fluke seem no better than a whole raft of much cheaper units nowadays.. I guess it is the 'eastern influence' again :eek:
