Mpg (1 Viewer)
DBK
18,049
48,218
Plympton, Devon
PVC, Murvi Morocco
If you aren't planning on driving long distances I don't think the mpg should be a limitation. For example, we might do 3,000 miles on a trip at typically 32 mpg. Alternatively, if we only got 16 mpg then we could probably still have had a good trip only doing 1,500 miles and spent the same amount on fuel, or even just 1,000 miles at around 10 mpg which is perhaps what that RV might do at a guess. :)
Jun 12, 2016
1,623
4,361
Scottish Borders
Globecar Revolution
Since 2006
I would investigate converting to LPG if it was a vehicle i was interested in
As DBK says if you are not planning long trips its not an issue
Check for damp etc as usual
RVs are built as well as other motorhomes!!!
Silver-Fox
9,285
29,280
Cheltenham Spa
Rapido
im a not so newbie
I know it’s a bit different but back in the day I used to run a Camaro with a 5.7 lt engine with an auto box.
If I took it steady she would return around 21 to the gallon.
I know your pulling a lot more weight but a light foot can help :)
Feb 24, 2013
13,110
101,580
Bolsover, Derbyshire
Hymer S800
not long enough
Looks like loads of MH for the money Bill (y)
I am really surprised it isn’t already converted to run off lpg, you might get lucky and find it is :)
If not too bad with damp and presuming it is genuine, I am wary of odd locations they make classic scans as they can’t easily be viewed, it looks a good find
MPG irrelevant IMO as said possibly just plan to do less miles (y) until your numbers come in that is :)
Feb 27, 2011
14,792
76,448
UK
Self Build
Yes none runner?? After all the treetment and two stents don't think I am up for a project just now
My vans a runner
And Ben in it two times this summer
Bill
ok. I saw the non runner bit and that it was a straight forward job (I believe) for you to fix thought you might get a bargain. However, I understand your point about health. That must come first.
