Mould Benimar 202 (1 Viewer)
1758Alfie
3
Motorhome
I have substantial mould appearing in all the mastic joints. the vehicle is only 18 months old. Has anyone else had this problem and did you get the supplier to rectify?
Cheshirecat57
3,482
5,590
Mid Cheshire
None
10 years on and off
Welcome to the forum
Mould is usually lack of ventilation and not usually a warranty issue
Is the issue in areas behind beds and in cupboards rammed full of stuff whilst in storage?
Minxy
32,700
66,736
E Yorks
Carthago Compactline
I'm assuming you mean the external joints rather than anything internal, if so it may be that the mastic used was faulty.
1758Alfie
3
Motorhome
Yes it's all external. The motorhome supplier is telling me this is normal and not a warranty issue.
TheBig1
17,649
43,471
An awful lot of vans about with discoloured mastic in the joints. First try a strong mix of traffic film remover, followed by plenty of water. In extreme cases scrape the joint out and use white spirit to clean up. Then reapply high quality sealant
Feb 5, 2020
2,384
89,439
Crosby
Smileo 202
Was a Newbie but getting the hang of it now.
1758Alfie welcome aboard from a fellow 202 owner!
We have mould spotting on the mastic outside on ours.
When cleaning the front screen last week I used some "Bug Remover" and noticed that it cleaned the spotting off very easily.
Jun 25, 2016
183
342
Ynys Môn, UK
2016 Benimar 243
Since 2016
I’ve used this quite successfully
1758Alfie
3
Motorhome
Thanks for all your replies, I give all remedies a go this weekend.
Apr 19, 2019
2,292
4,851
Carado T339
5 years
We had this with our benimar. Its not a serious issue. Its just a bit unsightly and the mould does stain the white sealant.
There must be something in the sealant that attracts the mould to grow on it.
You can save money by using some warm diluted bleach (which is all mould removers are really - oxidising agents). Just apply some bleach for just a short time. It will kill off any mould spores and also whiten the area. Only leave it on for a short time though as bleach (sodium hypochlorite) will damage the sealant if left in contact for long periods. Rinse it off thoroughly. A short sharp exposure won't harm it. Make sure the bleach doesn't go anywhere else.
