Morrisons Blanket Ban On Refilling All Lpg Tanks And Bottles (1 Viewer)
Aug 10, 2012
849
918
cambridge
Globecar
since2001
So just to clarify, I can or cannot fill my calor bottle at morrisons.
Have I wasted £30 on my eBay adapter?
Thanks in advance
Oct 5, 2012
4,282
9,569
Ayrshire
Carado T132
Thanks in advance
I think you will find you are breaking the contract between you and Calor gas. Which you took out when you 'rented' their cylinder, and they specifically state only Calor can refill.
I also believe you can only legally fill a cylinder on a forecourt to 80% so how you are going to acurately measure that is an issue.
I am assuming the 80% limit is there to protect the cylinder from being stressed from regular 100% fillings which may cause structural issues on the cylinder itself.
John & Joan
1,425
774
Darlington
10 years this time
The 80% limit is to prevent the liquid LPG from entering the regulator. The gap allows the gas to form. LPG expands 600 times from liquid to gas so if that gets in the pipelines it would flare beyond your control.
Oct 5, 2012
4,282
9,569
Ayrshire
Carado T132
Thanks for the clarification, certainly my experience with steel compressed air tanks is they are damaged and weakened by overfilling.
But more important, fill to 100% and the liquid is naturally very cold and therefore "small". Now you drive along on the sunny day, the liquid heats up, it expands, it has nowhere to go apart from the safety vent valve, so liquid LPG is forced out of the vent and if there is anything nearby to ignite it you are in deep deep poo.
DuxDeluxe
14,682
73,370
Planet Zog
A woosh bang van
Spot on, Brian. Any liquid needs an ullage space for expansion and contraction. On ships we used to fill to 98% full; having seen a liquid gas ship tank overflow (despite the safety shut offs) it is neither a pretty nor safe sight.......
Abacist
3,849
11,435
Devon
N & B Arto 88F Tag
since 2013
I am currently stuck with using Calor Gas so I don't and never have used LPG fuel pumps on garage forecourts. I am however interested in having such a system so I can enjoy the fuel saving.
If you have a vehicle powered by LPG then it is presumably turned off when you fill up.
This might not be the case with a motorhome where the gas could be on and lights up the pilot light for the fridge when the engine is turned off on the forecourt if the fridge was set to auto?
Does the act of refilling your tanks mean than the tank supply is shut off automatically so that the fridge pilot light goes out.
Perhaps someone has seen the potential risk of motorhomes having naked flames on their forecourts though in that case they would probably ban us altogether rather than just for gas?
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
I assume if you go to Morrisons to fill your car with LPG after converting it at home yourself, they will certify your installation as conforming to the Industry Standard and allow you to fill up at the same time?
mariner
1,283
3,778
Isle of Dogs, but mostly Artola Spain.
Caravan
Since 2007. But no more.
I think you will find that an Auto Fridge AES has a time delay before gas kicks in, for the very reason you stated.
:cooler:
Allanm
5,431
9,192
Since 1987
The gas for the fridge in my van is disabled for 15 minutes after I turn off the engine to allow for refuelling the LPG tank. There is a sticker in the van and the handbook that tells me this. It also says if I will be filling the tank for longer than 15 minutes after turning off the engine, to turn the main gas tap off first to stop the fridge burner igniting.
I don't buy petrol diesel or lpg or food fr Morrisons, so their well thought out logic won't effect me.
Abacist
3,849
11,435
Devon
N & B Arto 88F Tag
since 2013
The time delay is an excellent idea. I had not realised that. Thanks for the responses. All sounds pretty safe to me other than those who are refilling calor or similar type bottles themselves.
Oct 29, 2008
5,112
6,101
West Yorkshire
We use the Wakefield one with no trouble, if you go anywhere near either Morley or Honley the first is autogas station and second a texaco station it's only 47.9p per litre
Wheres the LPG pump at asda Morley. Ive not noticed it?
gwyntaxi
1,154
1,048
,Swansea
hymer starline 655
42yearscaravanning&motorhoming
Recently whilst reading a back issue of a motorhome magazine I came across an item which said Morrisons have introduced a blanket ban on motorhomes and caravans using the LPG pumps at their stations to fill up domestic gas. Now over the last few months I have filled up at their stations with no problems.
So I decided to call Morrisons head office to clarify the situation as UKLPG.ORG say it is fine to use autogas pumps to fill fixed tanks with external filling point as does the industry guidelines that I shared on another post.
I was on the phone for over an hour 10 days ago and no one could give me a answer however this morning I received an email from them confirming they had indeed a blanket ban in place.
Please read the following reply and leave constructive Response and I will reply to their idiotic blanket ban.
Good morning Mr Stancliffe
Thank you for contacting Morrisons
The safety of our customers and colleagues is our paramount concern. We take great care to
ensure that our petrol stations are safe environments and apply robust controls to reduce
the risk of fire and explosion and comply with all relevant health and safety legislation.
The LPG pumps on our forecourts are designed for use with automotive LPG tanks. For
safety reasons we do not allow the refuelling of other types of tank, such as portable
cylinders or fixed tanks used to power domestic appliances in caravans and motorhomes.
We are aware that some domestic tanks or portable cylinders are adapted or designed for
use with automotive LPG pumps. However, our forecourt operators are not in a position to
determine whether a system meets strict industry guidelines and can be considered safe.
We apologise if this causes any inconvenience, but believe that a blanket ban on the
refuelling of non-automotive LPG tanks is the best way to ensure the safety of our customers
and colleagues.
Many thanks
Daniel Wilkinson
Customer Services
Wm Morrison Supermarkets PLC
I feel this knee-jerk re-action has been brought about by caravanners/motor caravanners who have been filling CYLINDERS,in some cases NON-REFILLABLE cylinders on forecourts using adaptors that have been obtained on the internet,and "guessing" what 80% is I have been told by many a caravanner/ m/caravanner that they have done this some even bragging that they take the cylinders to forcourts in the boot of their cars to fill using this method,a typical example of a minority spoiling it for the rest of us responsible m/caravanners,I've no doubt that this will eventually spread to others companies' forecourts,making our bona fide properly install
-ed refillable systems redundant,because they are too bloody tight to buy a proper system.
gwyntaxi
1,154
1,048
,Swansea
hymer starline 655
As Morrisons state, their rules are for the safety of all their customers not just the half dozen motorhomes who are looking for a cheep refill.......;) Any retort will be seen by the masses as just another gripe by caravan dwellers.:)
Morrison's in Swansea has taken their LPG pump out,I wonder why.
wasp
1,724
18,180
Warsop
None gone caravannin
I did read that some BP service stations are removing Autogas pumps cos they not profitable.
I fill mine at the Shell garage on the Ollerton roundabout on the A614
43,447
50,403
It's not stirring anything up!
We spend most of our time off grid in the wilds and sometimes we may have a 50 mile round trip to a LPG station and the last thing we want is to get there and be refused.
The fact of the matter is they are going against industry guidelines which state autogas pumps can be used by motorhomes if filling point is a permanent fixture on the outside of the van.
I did ask for constructive comments to send back to Morrisons ! ;-)
What you forget is they are within their legal rigjts to refuse serving anyone for any reason.
Andi968
Andi968
55
41
Fenay Bridge
Autotrail TributeT725
5 year
And now a problem thanks to you
What planet are you on?
The ban was already officially in place!
All I have done is clarify the situation! As mentioned in a previous post the same letter circulated on the site previously.
Do you normally fill up at Morrisons? Or are you just jumping on the band wagon?
I spent well over a grand for my LPG system to be fitted to industry standard not some £19.99 crackpot adaptor for illegally refilling calorgas bottles.
If you want to blame anyone for this becoming a problem blame the people using these adapters! They are the ones directly at fault for creating the problem Morrisons are trying to solve.
Using LPG saves money and for people like me gives extra capacity, people who use these illegal adapters save even more but at the same time put everyone who they drive passed or pitch up next life's at risk.
As previously mentioned my system cost over a grand, there are some cheaper and some dearer but with my usage they had paid for themself in just over a year.
So to sum it up next time you try to blame someone look at the big picture because in my eyes my friend it is those people and their £19.99 illegal refill adapters 100% at fault for creating the problem in the first place, end of![/QUOTE]
D
Deleted member 29692
Thanks in advance
You can't legally fill your Calor bottles yourself anywhere so yes, you've wasted your £30
The only bottles you should be filling yourself are ones designed for the purpose with proper filler points and safety devices e.g. Gaslow, Gasit, Alugas.
D
But not being enforced. If they start enforcing it now as a result of you contacting them it really is your fault.
Forget their letter to you, there isn't a single instance anyone can come up with of someone being refused at Morrisons before you stirred them up.
Andi968
Andi968
55
41
Fenay Bridge
5 year
Not at all! It's the fault of the people who caused the problem in the first place illegally refilling bottle with adapters from eBay!.
I have just been reading the item that caused the problem have a read and draw your own conclusion.
To me it sounds like either filling point was inside locker (big no no) or using an adaptor. Interesting point from fire service!
http://www.manchestereveningnews.co.../eccles-morrisons-petrol-station-fire-7154094
Andi968
Andi968
55
41
Fenay Bridge
5 year
Give the guy a break! If I'd have seen the article in MMM, I would have written to Morrisons myself asking for clarification.
If you do see anything important and write to anyone, do yourself a favour and keep it to yourself and avoid a witch hunt ⚡⚡❄️
2,535
11,165
For Sale
