Morelo TV's (1 Viewer)
Mar 15, 2017
636
501
Berkshire
Hymer B ML T-780
Since 2017
This may sound like a stupid question but....
Is there any reason why I can switch my two German TV's for nice Samsung or LG 4K versions?
I expect you say that its because they are 12v versions but I always have 240v available so why not?
eddie
8,179
41,421
Taunton Somerset
RV
since 1989
In my Yank I have a 48" in the lounge, 40" in the bedroom and a 40" in a bespoke locker outside (Thought that this one would be naff and I'd be too embarrassed to use it but its great for sports events)
All smart in their own right, but HMDI linked to a HDMI distribution unit with Humax 1TB box, NowTV stick, Amazon Firestick and Google Chrome. All linked to the internal surround sound system, Sony sound bar and external waterproof speaker system, so no, absolutely no reason to compromise at all!
OurMoreloLife
Mar 15, 2017
636
501
Berkshire
Hymer B ML T-780
Since 2017
Blimey, that sounds like a great set-up!
Thanks, Eddie. Raises some interesting points too. Like, why do you have the NowTV, Amazon Fire and Google Chrome devices? Surely, basically, they all do the same job no?
OurMoreloLife
Mar 15, 2017
636
501
Berkshire
Hymer B ML T-780
Since 2017
Makes my plan for a PC monitor and a Firestick streaming Plex from home look pretty lame Eddie!
So I'm running Plex at home too but have no idea how to serve it up to the Morelo.
Would that require a VPN from home to the MH Michael?
OurMoreloLife
Mar 15, 2017
636
501
Berkshire
Hymer B ML T-780
Since 2017
No reason, I've never been very impressed with the AlphtronicTV's the Germans fit in all their vans.
Could it be the firmware installed in the TV to link with the Oyster satellite TV system tuning section maybe?
OurMoreloLife
Mar 15, 2017
636
501
Berkshire
Hymer B ML T-780
Since 2017
If you're thinking like that Michael, maybe you should get the factory to flood-wire your Morelo with CAT6 cabling as it's so much easier to do during the build than later; having a neat little ethernet outlet in multiple areas of the MH would be a great asset or better still, design it around your floor plan yourself now and have them install it for you (with all cables going back to a single 16 port ethernet POE switch in a locker somewhere).
I know most people would say "why do that when everything is wireless these days" but I like cables as they don't suffer the issues that wireless can do (like frequency congestion, drop-outs) etc.
eddie
8,179
41,421
Taunton Somerset
RV
since 1989
Now TV for Sky Sports (Rugby (y)) Amazon for Grand Tour and I tend to buy/download movies via Amazon Prime and Google Chrome so that I can cast my Samsung phone to all three TV's simultaneously.
The lounge TV can either play to a Sony sound bar or the internal or external sound systems, this is not for volume, quite the contrary. We took delivery at the end of July and didn't use it to the end of August, we had a great BBQ with some close friends, the girls wanted the "Greatest Showman" on (so did the boys truthfully :whistle:) so the alpha males crowded around the BBQ (because we were allowed to ;)) with the girls watched Zac and Hugh strut their stuff, but, when anyone went into the van, they didn't miss any of the action.
Some will consider it a waste of time, I don't and also I don't really care as I could compromise but don't want to, I have a good system setup through all parts of the house, so why should I compromise when I go camping! after all I could buy a tent and really get back to basics (if I didn't want my wife to ever join me again)
Lets be honest some luddites think that inverters and Lithium is some type of arcane art! So TV in a camper? shocking lol
Theonlysue
6,105
7,385
Essex
As Executive 50th an
Not long enough!
I'd stick with 12v. What happens when the 240 electric goes down?
Has happened to me on aires and campsites.
eddie
8,179
41,421
Taunton Somerset
RV
since 1989
Pretty much everything in the van is 220 VAC so relies on the inverter/charger, and with the setup we have we often don't bother plugging in depending on how long we stay.
In the Spring Summer we are self sufficient and in the Autumn and Winter, truthfully I would go to a site that didn't have decent facilities which normally equates to hook up as well
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
As it happens I have a static IP on the FTTP to the house, and the Plex server both local IP and roaming IP through forwarding ports. Because I have a static IP I am not sure if Plex operates its own DDNS as I have had no need to test it. As to serving it in the Morelo you just need a device running the Plex client, for example, a laptop, a phone or as I will use a Firestick which has a Plex client. I will be plugging the Firestick into the HDMI port of the monitor and it will wifi to my router, which has both cellular and hotspot wifi access. Actually pretty simple, just waiting for the monitor today. I know you have a Pointing all singing combo unit so it should not be an issue for you. I prefer a lego brick approach, with inherent redundancy. So I have a small TP router and a new Netgear Nighthawk M1, and an Ubiquiti Bullet. The nighthawk has a LTE MIMO dual antenna on the roof with motorised lifting mount and the bullet a 8db omni antenna up there too on another motorised mount. The two internet access sources are switched to the WAN port on the router with a manual R45 transfer switch so it is a manual selection not a software one.
I have got Morelo running 3 CAT 6 cables front to back but will use WiFi from the router predominately.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
F**K off big inverter with matching battery bank solves that! But my router and MIFI are all 12 volt. I think the TV is 12vdc from a brick but will know for sure when it arrives!!!:cool:
eddie
8,179
41,421
Taunton Somerset
RV
since 1989
Not had one myself just not thought much of them when I have seen them in friends vans, especially for the price they are.
Oyster? Soooo old school who has satellite TV nowadays ;)
Joking aside I did debate whether I bothered fitting Satellite TV on the new van, in the end decided that it was probably one van too soon to give it up completely
Having said that I used it once whilst away for New Year as I watched everything on demand as and when we wanted to, so in hindsight, so far it has been a waste of time
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
So I may be on the right track cancelling my Satellite.;)
Lenny HB
53,808
151,515
On the coast in West Sussex
Hymer B678 DL
I think you quoted the wrong post Eddie I was refering to the TV. :)
eddie
8,179
41,421
Taunton Somerset
RV
since 1989
truthfully? Possibly. I genuinely did chat with my wife, and with the guys in the office and as I said in my last post, decide that as of September 2018 it would on balance "probably" still needed, but, my pattern tends to be to change the camper every four'ish years and I really struggle to think that we will be installing a satellite system on Ed's 2021 motorhome
OurMoreloLife
Mar 15, 2017
636
501
Berkshire
Hymer B ML T-780
Since 2017
What happens? Er, we talk to each other or read a book/kindle.
I have lithium cells with amazing capacity through the inverter and can honestly say I've had few issues. I also have a dual fuel generator if I'm far enough away from other people to feel it's fair to use, so 'not a problem' I suppose is the more accurate answer.
OurMoreloLife
Mar 15, 2017
636
501
Berkshire
Hymer B ML T-780
Since 2017
[QUOTE=" Lets be honest some luddites think that inverters and Lithium is some type of arcane art! So TV in a camper? shocking lol[/QUOTE]
Loving that reply :ROFLMAO:
eddie
8,179
41,421
Taunton Somerset
RV
since 1989
I have lithium cells with amazing capacity through the inverter and can honestly say I've had no issues. I also have a dual fuel generator if I'm far enough away from other people to feel it's fair to use, so 'not a problem' I suppose is the more accurate answer.
That is a very good point, although many of us have some amazing technology, it is only there so it works, how we want it, when we want it. When on our own we spend more time playing Backgammon, Cards or Rummikub
All of which requires a partner, not power lol
eddie
8,179
41,421
Taunton Somerset
RV
since 1989
Loving that reply :ROFLMAO:[/QUOTE]
I shall be at the mercy of many at the NEC next month. You will be amazed how many people will make a beeline to the Van Bitz stand to tell me what I don't need and why I am an idiot for having:- (Delete as applicable)
Sat Nav
Satellite TV
Inverter
Lithium Batteries
Generator
Solar Panels
Tracking
Motorhome alarm
Reversing camera
Side view cameras
Slide outs
Leveling jacks
My colleagues do try to shield me a bit and deflect a large number of pointless arguments by clocking the attire and manner, typically Gravy dribbles down the front of their Hofmeister sweat shirt, gravy dribbles despite it being only 10am, so not a fresh stain, having a pungent whiff of "damp" with a souciant of body odour about them, and normally their opening gambit is, "Right which one of you lot is Eddie" as their tongue wrestles with the errant false teeth that presumably once fitted superbly, just not the current user!
Oh we run the gauntlet to offer toys! we really do!
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Didn't know they had a bad reputation, we have an Alphatronic in our imported one.
So do we.
Excellent picture quality although the sound isn't brilliant.
That's not a problem for us though as the sound gets piped through the radio and speakers.
Richard.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Just connected up my new Lenovo 22inch monitor to the Firestick, connected to all the test WiFi mifi for the new van, and wow the Firestick is just what I needed. Downloaded the Plex client and signed in to all the streaming accounts and it is ideal, all for ÂŁ200. Just need a Vesa 100 locking swivel mount.
Theonlysue
6,105
7,385
Essex
Not long enough!
I've had an Alphatronic. Swapped for Avtex. Programme guide better.
Surely more efficient to have 12v tv, rather than run 240v through invertor??
eddie
8,179
41,421
Taunton Somerset
RV
since 1989
If they did 48" smart TV's in 12 VDV i
I'd be the first in the queue (y)
