More help! Which engine oil? (1 Viewer)
Feb 27, 2011
14,778
76,387
UK
Self Build
But the dealer should have done a pre delivery inspection before giving it to you so they need to take a bit of responsibility?😊🤔
Only so much that can be checked. Not sure I would check for an oil cap pre-purchase tbh.
OldCodger
OldCodger
858
202,470
Surrey, UK
Carthago I 143 LE
Since 2016
They won't have found one. Everytime I have seen this job done the cap gets perched somewhere in the engine bay while the task is done. When the van is driven off it will drop out somewhere enroute.
You might even get lucky and find it lodged somewhere in the engine bay.
I will look tomorrow, but I’m not holding my breath!
TheBig1
17,645
43,461
Most likely the oil cap is sat on the engine under tray
Apr 3, 2018
3,693
10,279
PVC
1995-2004 & 2017》
IMHO.. if you drove 200miles and no oil pressure warnings appeared ( I assume Ducatos have a low oil pressure warning as reading posts on here they seem to be totally differant to any vehicle I have ever owned) then there was obviously enough oil in engine to do the job.👍👍
OldCodger
OldCodger
858
202,470
Surrey, UK
Carthago I 143 LE
Since 2016
Jun 12, 2017
1,443
3,670
Telford
A class Pilote
My mechanic told me in the 70’s when I asked him which was the best oil his reply was any oil is better than no oil. In my opinion that still stands😜
Oct 7, 2015
737
3,578
newark
Swift escape 624
I have yet to find a service bay that fills an engine to the full mark , most fill to minimum and charge full price, ie Ducati 150 states 7 ltrs but they only put in six, as overfilled can cause problems, I say this as 50 years in the trade it was the same just about everywhere.
Steve N Tracy
1,237
3,759
Southampton
4 Years
Wilmoths in Southampton do they overfilled mine, and with the wrong grade, mines a Euro 6 and they put in 5w 30 not the 0w30 specified, when I questioned it they said the book says 7 litres so that's what they put in.
They weren't to happy about having to drain it and refill.
Apr 20, 2022
654
1,215
Brighouse, UK
Autoquest 155 2016
Since 2020
My wife’s car always comes back from the dealer with about 3/4 litre too much in. When questioned they say that it takes 5.2 litres. I say why don’t you use the dipstick ?
I suck it out with an extractor. Twice that’s happened.
OldCodger
OldCodger
858
202,470
Surrey, UK
Carthago I 143 LE
Since 2016
The cap is definitely not on the sump guard.
Can someone tell me if the the sump guard is supposed to be across the whole of the engine bay? This is what I have
OldCodger
OldCodger
858
202,470
Surrey, UK
Carthago I 143 LE
Since 2016
But the good news is, the sump plug and oil filter are both tight! 🤔
Feb 27, 2011
14,778
76,387
UK
Self Build
I suspect the cap is in a grass verge somewhere between the garage and your house...
Hopefully your replacement one arrives today and then everything will be well with the world.
I would look at the oil coating as a "free" rust proof coating :p (y)
Feb 20, 2017
861
2,471
Kent
Bailey 75-2
Tugger now Motorhome
On my Peugeot it is the same. You can buy the rest of the bits on EBay. My Euro6 engine has very specific oil requirements according to the Handbook.
Oil 7 litres Total Quartz Ineo First 0W30 & filter change or Shell Helix Ultra Professional AP-L Engine Oil -0W-30
Expensive - two 5litre containers are the best part of £100
Dec 12, 2010
5,429
21,701
Cumbria
since 2011
Looks to me like the middle section of the under tray is missing ?
Why would a manufacturer fit that offside section of under tray you can see in the pictures, but leave out the middle bit, plus the sump and exposed engine components look fairly clean, almost as if there's been some sort of "shield" protecting them in the past ? :unsure:
Under trays can be the bane of servicing mechanics, the clips and screws never come out, or go back in easily and some shady mechs will just skip them rather than struggle on with them, I'd be looking to locate a replacement.
Jul 29, 2013
9,076
18,646
Salisbury
Hymer B678DL A class
since 2011
Westway Oils £28.99 for 5ltrs 0W30 C2😊
Lenny HB
53,696
150,979
On the coast in West Sussex
Hymer B678 DL
OldCodger
OldCodger
858
202,470
Surrey, UK
Carthago I 143 LE
Since 2016
Looking on flea bay there’s several options, but in general it looks like I only have the near side section the centre and offside are AWOL. From a quick chat with the guys at google, it’s a common problem. Various MoHos have various bits oresent
£100 squid to replace
Lenny HB
53,696
150,979
Hymer B678 DL
Mine have always had both sides just centre missing
