Mixer tap pressure (1 Viewer)
Jul 29, 2013
9,090
18,884
Salisbury
Hymer B678DL A class
since 2011
Hi all we are experiencing very low flow rate on hot water in the kitchen mixer tap which is a bit baffling as the shower and wash basin mixers are fine and good flow I have done the usual checks for leaks and cannot find anything? Am wondering if the tap is just fired up as the cold has a really good flow?šŸ¤”
Aug 6, 2013
11,963
16,583
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Remove & clean the flow straightener on the kitchen tap. They have a fine mesh filter that easily clogs.
Landy Andy too quick šŸ˜
Lenny HB
54,069
152,578
On the coast in West Sussex
Hymer B678 DL
Could be a scale build up in the cartridge, you could try swapping the tap or just the cartridge from the washbasin, apart from the kitchen tap swiveling they are the same Reich tap.
Speve
Jul 29, 2013
9,090
18,884
Salisbury
since 2011
I donā€™t think I can get the flow straightener out but will experiment
is it easy to take out the cartridge Lenny?
Apr 27, 2008
11,860
14,110
Eastbourne East Sussex
Hymer low profile
Since 1972
If the cold flow is OK and it's only the hot that's slow it's not likely to be the strainer thingy though they do clog up but that would affect both. Possible cartridge blocked.
Lenny HB
54,069
152,578
Hymer B678 DL
I think so I've only taken the taps apart to repair the microswitches. After taking the leaver off remove the Torx head grub screw at the base on the rear of the tap and the body slides off.
While you are at replace the socket cap screw that hold the lever on, they are unplated steel and rust well, they are only screwed into nylon so they will still come out. I replaced them with SS screws in all three taps.
Speve
Jul 29, 2013
9,090
18,884
Salisbury
since 2011
Iā€™ll give it a go when its raining again, hopefully that wonā€™t be till we get back to the UK?šŸ˜‚
Speve
Jul 29, 2013
9,090
18,884
Salisbury
since 2011
Thanks everyone for your suggestions it turned out to be the short pipe connecting the submersible pump inside the tank had come off so assume in the process lost pressure tightened up jubilee clip all working againšŸ˜Š
Down to some very potholed roads on the way here I think some of them would shake your teeth loosešŸ˜‚šŸ˜‚
Lenny HB
54,069
152,578
Hymer B678 DL
When I still had the submersible pump that use to happen on mine at least twice a year.
Jan 1, 2019
762
1,427
Pembrokeshire
Hymer B704 PL
Since 2017
Got to say that has happened to us a number of times. In the end I used two jubilee clips and some plumbers sealant. ā€˜Belt and bracesā€™ I know but not come off again since.
Poor design in my opinion
Speve
Jul 29, 2013
9,090
18,884
Salisbury
since 2011
Yes a bit like the tap that drains the tank there have been a few problems with them over the yearsšŸ™„
Apr 19, 2019
2,295
4,862
Carado T339
5 years
We have a good flow on the kitchen tap and shower but bathroom tap down to a trickle. Anyone any ideas/instructions?
Oct 13, 2016
1,053
897
Grays - Essex - UK
Mercedes Hymer B680
Been mohoā€™ing for a time now
If like ours all taps are fed from the same pump, probably a blockage of some sort, between the pump and the bathroom tap ?
762
1,427
Pembrokeshire
Hymer B704 PL
Since 2017
This was the problem with my MH and the microswitch needed changing. It depends on what water pump system you have fitted?
