Mitre Saw (1 Viewer)
TheBig1
17,644
43,457
how long is a piece of string type question. I have a few different types in the workshop, all for different jobs
Jan 8, 2013
8,494
11,531
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I have one of these - seems to do everything I need it to
Link Removed
Mark and Mindy
1,031
4,813
Nr Bicester
Adria Twin 640 SGX
Since 2019
I have an Evolution mitre saw similar to the one posted above but it's colour is green not orange and I don't know if that makes a difference.
It's not an expensive model and I liked it because it says the one supplied blade will cut through almost anything which means I didn't really have to worry about what I was cutting or if the wood had nails.
Main feature I like is that it is a sliding mitre saw so get the one that can cut the widest stuff.
The laser is useful but a bit dodgy and actually easy to knock out of alignment.
I also purchased the stand which was very useful to have a study stand but it almost cost as much as the saw itself.
Mark
Jul 29, 2007
6,554
39,738
Ipswich
RV and PVC
30 years
Unless your going to use it professionally buy a cheap one for £100 or so, some of the cheap gear is surprisingly good inspite of what people say. Near enough all of the well known makes are now made in the far east and generally aren't the quality they used to be.
makems
3,440
27,728
Ingleby Barwick,,Teesside
Sadly had to give up
Depends how much you are going to use it and what degree of accuracy you require.
if you are planning on using it as part of your job or trade buy the best you can afford,
If you are just going to do the occasional bit of carpentry, buy cheap.
When I lived in the States and was refurbing a house, i bought a top DeWalt model and it was great. Powerful, large dia blade and very accurate with no play or movement once an angle was set so accurate cuts could be repeated time after time.
Since being back in the UK i have had a couple of cheap modeks from B&Q which did a satisfactory job. I burnt the first one out doing a lot of laminate flooring on a few houses so if you have a lot to do, don’t buy cheap.
Once you have decided whether you need to spend a lot or a little money, then look at features:
1. size of blade is important - remember that when cutting at an angle the length of cut is much more than the width of the material you are cutting. Eg 150mm wide plank cut at 45 degrees needs a minimum 225mm blade.
2. get a compound mitre saw which can cut at an angle in 2 planes in one cut. You might think you don’t need it, but you probably will sooner or later and its a hell of a lot easier than trying to work out how to do it in 2 cuts (and if you’re like me cocking it up 2 or 3 times).
HTH
4,510
52,986
Surrey
Carthago C Tourer
Makita or Bosch Tools have always served me well.
Keep your eye on deals at Screwfix, and Amazon, get one with a nice big motor 2KW or so,and a solid cast base plate, that allows good secure clamping of angles, and accurate measuring on degree angles etc.
The blades have 20mm diameter centre hole, so plenty of choice for fine or rough work, however you should get a good quality multi purpose one with saw itself.
LES
Silver-Fox
9,278
29,189
Cheltenham Spa
Rapido
im a not so newbie
Thinking about replacing some woo on a boundary wall and building a workbench, nothing heavy
You need to make sure the wood will fit under the blade and the blade will go through the wood then.
Some smaller saws foul on the motor.
Mar 23, 2012
9,580
32,229
sleights
c class
I found that when the blade on my cheap one needed replacing a good quality blade transformed the saw making it a lot more accurate and quick to cut.
I think the saw was from Screwfix who are part of b and q
Bailey58
8,836
29,815
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Depending on the width of wood you're cutting you may need a sliding mitre saw. I have one in my Amazon basket for a job in the Faroes this summer. I've also got it on Camel Camel awaiting a price drop, hopefully.
Jun 17, 2012
2,937
9,986
North Essex
Autotrail Delaware
>12 but <13
Don't forget to do a risk assessment prior to each use.
May be best to invite H & S executive along as well.
Then there's the hard hat, the hi-viz tabard, goggles, gloves etc. :giggle:
Dec 12, 2010
5,427
21,683
Cumbria
since 2011
I have an Evolution Rage, 10" blade and 300mm cut mitre saw, I got it on offer at Screwfix. I bought it after I had been using an Evolution 8" circular saw for ripping some floor boards then cutting 6 mm steel chequer plate with the same blade. The blades last surprisingly well on steel, but I have been buying replacements made by Erbauer for about a third of the price of the Evo ones. I also bought the mitre saw stand that was on offer in Aldi. It was about one third the price of my neighbour's Bosch one and the end supports are adjustable rollers, not square section like the Bosch.
Like The Wino says, buy yourself a specific blade if you're gonna do anything fancy. I cut some oak veneered mdf skirting with mine and it was fine with the new blade and slow feed, but I'd change the blade if I had a lot to do.
Feb 22, 2008
12,268
45,072
Norfolk
Nearly Tugging
Since 2004
Do you want compound mitre saw or sliding compound mitre saw. Link gives an indication of prices and there are sometimes deals from Toolstation and Screwfix. A sliding saw will give a wider cutting width.
Link Removed
Aug 4, 2016
608
1,375
Yorkshire
Vantage Neo
Since 2003
Probably better off with a Meglinator, wouldn't be without mine. Don't forget the safety goggles as well.
Gellyneck
9,267
18,409
Scotland
More than toes wet now!
Evolution Rage for us as well.
Was in Screwfix yesterday and they appear to have some models on run out at the moment.
Gellyneck
9,267
18,409
Scotland
Yes they've bloody ruined the place, everything is now as expensive as B&Q. I now go to Toolstation.. ? Until they buy that as well ?
Funnily enough Toolstation was started by the same guys as Screwfix after they sold it to Kingfisher Group (B&Q parent group) so wouldn't surprise me!:rolleyes:
Bailey58
8,836
29,815
Norfolk and Toftir.
Sold
Thanks for that, I've binned the one in my Amazon basket and bought the Evolution plus half price stand. (y)
tonka
10,842
21,557
Cannock, Staffs
A class Burstner 800
Since 2000
(y)
Toolstation now owner by Travis Perkins..
We are lucky with B&Q, Screwfix and Toolstaion all withing a few hundred meters of each other.
Handy when shopping around or if one does not have something.
thebriars
1,149
2,182
Teesside
Since 1990
Lidl sometimes have them in their middle of Lidl. Good quality and 3 years warranty.
Mar 23, 2012
9,580
32,229
sleights
c class
Toolstation I think is the same as wickes and travis perkins. I think Screwfix has always been part of b and q but as time has gone on the prices have risen.
Jul 12, 2013
3,876
5,283
The City of Henlow
Adria Supreme
Since 1980
Another vote for the Evolution. Blades are readily available, so not a problem. I was amazed that the blade which is not expensive will cut anything, plastic, wood copper and steel. That answered all my questions. I love it.
Apr 22, 2018
6,827
12,598
Herts.
Adria Coral lowline
Don’t mess about with all that cheap tat. Quality is what you need for tools
