MiMo antenna (1 Viewer)
Jun 10, 2010
8,521
20,233
Shrewsbury (sometimes)
N&B Clou Liner MAN
Gellyneck, it's the only photo I've got showing the Poynting MiMo antenna.
The sheathed cables run under the front right edge of the smoked skylight, up and over the interior frame, (after a minor adjustment to the plastic profile was made, to accommodate the cables), then discreetly hidden by the frame trim, exiting at the corner nearest the MiFi.
The two in one adapter lead you see is only temporary, until the newer Cat 6 MiFi arrives, to replace the Cat 4 model.
Jock. :)
Do you remember what leads were in the box please Jock?
Nov 13, 2011
1,481
3,522
Lincolnshire
PVC
30 years
If it helps anyone there are threaded inserts in the base. I have a PVC, so steel roof. I used four strong magnetic discs and stainless steel countersunk screws. It will not move without a considerable amount of force, but I can simply remove it if need be.
Geoff
JockandRita
11,464
150,284
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
These SMA ones Jon, but then I had to by the small conversion lead to fit the TS9 ports on the MiFi.
HTH,
Jock. :)
P.S. I have since changed the MiFi for a Cat 6 model, hence the untidy cable configuration. ;)
