microwaves in motorhomes? (1 Viewer)
buzzard
24
11
Allestree, Derbyshire
Van conversion
since 2008
Hi,all am new to motorhomes,have just bought autocruise stardream on 55 plate, am wondering if i could use ordinary microwave in van -or do i have to buy motorhome specific? ihope someone out there can help me! look forward to any replies,thanks..buzzard:RollEyes:
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
You can use one from home. Your still running on 230V when hooked up and when your genny is running.
Jim
:Smile:
Welcome to Fun
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Microwave, using sites with elctric hookup, as Jim says normal household 230/240 volt job, and again the same if you run a geni. I've heard rumor of 12volt but never seen one.
Important thing I would say, go for a low ish wattage, less chance of overloading supply:thumb:
PS Hello:thumb:::bigsmile:
Sep 29, 2007
813
1,193
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
As madbluemad says, you can use the one from the kitchen.
Perhaps you need to be aware of two things:
1. If you plan to run it off an inverter you must take into account the fact that it will use a LOT of battery
2. Remember that a 800w micro doesn't use 800w of power, it uses much more (well over 1kw). Some others may have more experience on this, but the bigger micros are border-line on some of the 5 amp supplies in Europe, especially if your van is charging and you turn the microwave on.
Might be a plan to get a smaller micro from somewhere like Tescos.
Rog
Sep 29, 2007
813
1,193
Wantage, UK
I just ran my 800w micro through a tester
Peak watts: 1380
Peak amps: 6.4
The average was slightly less (around 1350watts).
That means you can't run it on a 5amp circuit breaker (assuming my tester is accurate).
Another point: if you run it on a cheaper inverter (not a pure sine wave) it will need even more power (we found that a 1.5kw cheapo was not good eanough, so got a 1.5kw pure sine wave and it works fine).
Rog
Apr 27, 2008
11,858
14,106
Eastbourne East Sussex
Hymer low profile
Since 1972
Get a cheap one from Tesco/Asda for around £25 quid. If its got a glass turntable take it off when travelling or you may do damage to the interior.
There are 12v ones but they are basically mains one's with a built in inverter and cost a fortune.
Apr 29, 2009
2,321
1,991
West Yorkshire...Halifax
Vanless....BUT....!!!!
The thing to take into account with a microwave is that the power it runs at be it 650/700/800 watts is different to it's start up power.. at start up a lot of these are double the power..so they can be from 1300-1600 watts and if you have a 230 volt EHU the amperage will be anything from 5.6 amps to 6.9 amps.. if my Ohms Law calculations are still correct so as said a lower wattage is preferable!!
scotjimland
2,481
10,856
A Woosh bang
Should also be noted, they are rated in COOKING power . not power consumption
a 1,000 watt cooking power oven actually consumes 1,500 watt or 6.5 amps
start up or inrush current may be several times higher..
to check the power used look at the data plate
estcres
1,300
767
Sunny Bournemouth
coachbuilt
since 2005
didnt know there was a12volt microwave:RollEyes:
You can get 12 volt microwave cookers but they have to be wired in a specific manner.
They must be connected directly to the battery and not through the vans wiring system.
Just look at these calculations. 800watts/230volts = 3.48Amps
800watts/12volts = 66.67Amps
Hope that helps.
Dalek
1,343
123
Norwich
Roller Team 600
18 months
We have a Tesco one that Graham fitted into the garage of m/h. Re the glass turntable we use a tea cosy to keep glass in when travelling.
freelanderuk
1,018
534
Saltfleet/Lincolnshire
c class
we bought the cheapest and smallest one from Argos and have never had a problem with it , been in the van 2 years now and used when the kettle is boiling and tv on and never tripped the elecy
chatter
3,689
937
cheshire
5th wheel
just for you dodgey, you can get them but they are way ott on price
Link Removed
Oct 29, 2008
5,106
6,082
West Yorkshire
PVC
since 2008
I have a Samsung junior microwave for sale. It is 550w and will run on my 1000w inverter or 240v . They are very hard to find and are nice and small for a MH. I want £60 for it.
