Mice! (1 Viewer)
Jun 12, 2014
40
46
Fife
Low profile
Since1982
Over the Christmas period, discovered mice droppings in the drawers at floor level and on top of the table and hob, despite having an ultrasonic mouse machine switched on. It is the first time since we started motorhoming in the early eighties that we have ever had these unwelcome guests. Anyway, put down a couple of traps and caught two of them. The only place I could see where they had got in was on the rear wheel side of the entrance step where there is a slot cut in the floor for all the cables to enter the inside of the van under the fridge. I pumped in a heap of expanding foam, and touch wood, seem to have got rid of them. Just a warning if anybody else suffers the same problem.
43,396
49,921
If that is the only entry point, which is doubtful, you may have trapped more inside.
And a couple of mice with nothing better to do...... Well, work it out. :xlaugh:
movan
21,492
120,753
Moving around
Burstner
since07
..they learn to play guitar?? ;)
Also buy lots of Lavender oil and sprinkle copiously around van interior ... it does help keep them out along with your other deterrant efforts.
Blue Knight
5,232
5,704
Durham
Globecar Summit 640
I would also keep an eye on the floor gas vent; the Truma inlet air pipe and the joins in the chassis where the front cab and the van sections meet.
It may also be a good idea to have a quick check of your air and inlet manifold to see if the little monsters have nested or taken up residence.
Feb 22, 2008
12,270
45,081
Norfolk
Two wheel job towed.
Since 2004
Aaahh , sweet smelling meeces :xgrin:
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
I was told that mice and rats piddle as they travel leaving a trail for others to follow. So if you spray around the outside with jeyes fluid this will break the trail and deter others from following.
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
What if Lavender oil is an aphrodisiac to Jerry & his partner, if you find tiny little scented candles around the shower you may be in trouble ;) :p
PP Bear
7,858
29,052
Kent, UK
Auto Trail Dakota SE
They got in mine by running along the driveshaft and up the steering column. Lots of poop and piddle on the dashboard.
They built a huge nest under the dashboard on the drivers side. Had to remove the dash and vents and hoovered the nest out. Didn't find any mice in the nest, but lots of conkers stored for the winter months. Seems they'd been quite busy.
Set a humane trap and caught them quite nicely, just can't kill them, and then let them go away from home.
Apr 27, 2008
11,856
14,103
Eastbourne East Sussex
Hymer low profile
Since 1972
Throughout the winter I have 6 baited neck breaking traps set. Rarely catch anything now but first time I did this I caught 18 mice in a week in spite of the rodent repellent gadget. No point in humane traps as mh is in storage and is only checked weekly or less so will starve to death which isn't very humane.
K
Jun 12, 2014
40
46
Fife
Low profile
Since1982
Thanks guys for all your inputs. I caught two in traps in the van, and left a further 4 traps set for 5 days after blocking up the hole under the fridge. No more signs of any mice. Went away for a days run and had heater on full as well as water heater. Everything works as it should, so assume that problem has gone. Incidentally, had 4 mice caught in an outhouse away from the shed that the van was being stored in at the same time, and have had no more of the blighters for over a week now.
