Mercedes Rapido 9 series (1 Viewer)
Apr 12, 2013
1,072
2,177
Shrewsbury
Carthago 144
Since I purchased my 2008 Rapido on Mercedes chasis in March 2017 I noticed a knock from the front left hand corner , suspected the shock absorber but all checked ok. knock was more noticeable when stationary and moving about in motorhome. Finally I started looking inside small inspection panel under the dash and removed insulation material to find water ingress to side panel . The dashboard bolts through the side panel with some sort of coach bolt and that's making the noise. I inspected under the wheel arch and to my surprised the plastic under tray has a gap of a couple of inches
There is nothing to stop water and spray going up behind the side panel board , resulting in damage to boarding . Its just thin furniture board with no water protection whatsoever. The dealer I purchased it from has agreed ( after a bit of a fight as its out of its six month warranty ) to repair the damage free of charge.
So I would urge all Rapido 9 series owners to check under the wheel arch and see if there is any protection from water damage.
