I have a Maxview 65cm seeker on our caravan and never had any issues with except when it needed a software update which was easily done by downloading to a USB stick from my laptop and updating the maxview control box . I would say its just as good as the more expensive German satellite we have fitted to our Motorhome .Has anyone had problems with the seeker satellite. My 18 month old one played up quite a few times then completely failed.They fitted a new unit about 3 months ago now it has failed again. Anyone had problems,
Ok sounds like the problem I had with my Maxview and its a fairly easy fix if you can get to your Satellite , if you unbolt the six 10mm captive bolts that hold the dish to the base plate and carefully lift the unit up and tilt to allow access to the underside there are two multi plugs and two satellite feed cables .After telling them the error code,Maxview say it’s a connection problem (wiring) in the dish. Okay if you carry a ladder and toolbox
