Looking at 9048DF - a few questions :-) (1 Viewer)
Feb 18, 2022
150
147
Suffolk, UK
Rapido 9048DF 2016
Noting that it seems hauntingly similar to a Hymer B544 (we used to own one) so I keep having to tell myself not to assume anything!
The one we are looking at seems a lovely van and generally well constructed.
The one thing which doesn't look so good is the door and drawer catches.
One catch is missing, others don't seem robust (push and click variety).
Is this a known issue or has the van been previously owned by someone heavy handed?
For the kitchen drawers, there is a knob which moves a locking bar (much like in a filing cabinet) so you slide the drawer fully closed then drop the bar behind the little metal bracket to stop the drawer opening.
The large drawer won't close with the locking bar up - seems to be catching on the bracket.
Small drawer is fine.
Generally, are these known problems?
What other known problems should we look out for?
Obviously the dealer will service the MH prior to hand over (assuming we do the deal) but it would be good to know what else to check.
Oh, and the grey water drain (as far as I can tell) is just behind the near side rear wheel.
However it is a short stub of a pipe well out of reach without a crawling board.
In the Hymer we had an extension hose which fitted over the outlet and could then have the other end in a grid.
With the Rapido 9048DF do you just park over a grid and hope?
Aug 26, 2008
4,771
25,063
B&NES
Van Conversion
since 2007
Push and click locker catches are cheap and simple to replace. Our Rapido Van uses them. Have had one fail so far but not a big deal. Edit - they come in 2 sizes so get the right one.
If the grey water dump valve is like ours, we use a drive-over grid and pull the handle at the nearside to open. Have not bothered with an extension hose.
L
Feb 18, 2022
150
147
Suffolk, UK
Rapido 9048DF 2016
Just checked previous MOTs and found:
"projected beam image is obviously incorrect"
for both headlights.
This can be caused by setting the headlights to LHD.
I remember being able to do this on my Hymer B544 2002.
Can you rotate the headlights between RHD and LHD on the 9048DF?
Feb 14, 2014
572
6,115
Ainsworth, Bolton, UK
since 2011
Hi we have a 2016 9048df and its the best van we have ever had.
You can change the beams via a screw on the fitting but I have not done so.
The dump valve is located under the floor near bathroom door so we normaly put an extension pipe and run straight into a drain or a bucket if no drive over drain available, as for the other items I would think they just need adjusting
Gary
Tombola
4,847
15,759
Merseyside
Rapido 8094DF
Since 2004
I Have an 8094 DF and the cupboard catches are th epush type. WELL more like slam type you hve to give them a good shove.
I try and do it gently if close to another van as you can hear ot seem like slamming from out side, and Ive trapped my finger a coupe of times tryng to be courteous LOL
Apart from that I love the van.
Sep 18, 2015
698
702
Selby, North Yorkshire
Rapido 8066DF
The catches on the overhead lockers can be adjusted, but if you pull down on the handle just before it closes they are much better to close, well i have found that anyway.
Jul 9, 2018
461
812
Globecar Campscout
since 2016
I made an extension for mine is fine if its a long drain type but there are a lot of smaller ones I've found. Works for me as I know if my rear wheel is just passed the drain I'm OK. Also made up a small extension as well.
I think colpaz do kit you can buy that would do the same. I just had some bits and pieces in the garage.
We have a 809odf
Oct 10, 2023
26
33
Valencia, Spain
Rapido 9648DF
In ours (2012), we removed the whole pipe. because it was off centre - and most grill drains are central - it was always a faff. By removing the plumbing pipe, its now central and also smack in line with rear axle, so easy to have a good guess at positioning without all that back/forward waving nonsense that we used to have. Never seen the need for a bucket or anything because we only do one or two days and move on... but if you had too, it would be very difficult now.
just spent a few days looking at upgrading to a different model, but cant find anything with the internal space like our 9048 (our Tardis) , so gonna do it up a little and give it another 10 years.
Has anyone done any nice upgrades to their interiors that i could nick ideas from ? Weve removed quite a few of the cushions from seats we never sit in.... apart from that , the lower underneath storage is a bit awkward, id like some sort of pull out shelves on runners so that I'm not having to kneel down to peer in...
