Lithium fire extinguisher (2 Viewers)
suavecarve
7,608
39,216
Surrey/Hants
Rollerteam 685
July 09
Information only.
At work we have just got a Lithium Battery fire putter outer.
I get instructions later this week on how to use it but here is a video they provided
I know little else about it. Just in case someone is concerned enough to carry one for their bikes/scooters/hab batteries
Oct 12, 2009
10,763
23,848
A Class N+B Arto 69GL
Since 2009
Ask the instructor about the chemistry involved and a briefing sheet on it too, which you could then post on here.
Was the demonstration on a Lithium-Ion battery or a LiFePO4?
suavecarve
suavecarve
7,608
39,216
Surrey/Hants
Rollerteam 685
July 09
I m only possession of the information that we are getting one and the video at the moment.
I wont be on days til next Monday when rest assured, the necessary questions and where to buy it and how much will be asked
Tombola
4,877
15,826
Merseyside
Rapido 8094DF
Since 2004
Interesting...wonder if its jactone who makes it..and what's the difference.
Edit says UK manufacture
suavecarve
suavecarve
7,608
39,216
Surrey/Hants
Rollerteam 685
July 09
An update.
I wanted more than the video as training so went down to where we have the extinguisher and spoke to the lady who oversees our battery storage area.
First up she tells me she has had 3 blown lithium batteries in the past month. I found this a little shocking as I thought we would be the ones attending this type of incident, but it appears our students like to make their own batteries and then discard them to her area where they are proven to be, not so well made.
At this point I thought I definitely need to know a little more than I thought I would need i.e. how to point a fire extinguisher so quickly arranged training for my team (I couldnt attend the full training as dealing with an incident at my chosen time)
In the meantime I bumped into our Fire safety man who agreed we ought to have quicker access to lithium fire extinguisher and we will get 2 (one for each campus) and will pass on my details to the company so I can see if it is worthy of having one in the motorhome (for anyone reading this as I wont be now)
The boys (and now a girl as well) came back from their training and said that it was pretty easy. Call Trumpton. If a lithium battery is on fire in an enclosed space, dont tackle it without BA equipment.
Owing to my lithium battery within my motorhome being in an enclosed space I wont be tackling it with an extinguisher so therefore wont need one and wont be buying one. I will find out how much they cost for you though hopefully.
More interestingly were the buckets of "pebbles" we have to put the lithium batteries into (when in cell format) when blown as they react and form a glass seal around the battery. But we are unlikely to use that as it is going to happen in the storage area.
Apr 15, 2022
11
27
Swift Histyle 640
My lithium overheated in our motorhome while i was on nights, luckily the wifes a light sleeper and was woken by the smoke alarm, when she went out she said the motorhome was full of thick smoke, the fire service attended in minutes and made it safe by extracting it, as there were no flames at the time and it had not got as bad as to ignite the seat or anything else, not sure how much help one of these would have been for us, now scared of lithium and gone for a couple of gels
A couple of days prior someones pvc was burned out with the same issue, we were the lucky ones
Kannon Fodda
2,609
8,071
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
Which brand / model of lithium leisure battery was this please? Was it LifeP04 which is widely quoted on this forum as low risk, or another chemistry?
Jul 29, 2022
520
914
Watford, Hertfordshire, UK
Swift Kon-Tiki 599 S
From Frogstar Batteries
"Research has shown that LiFePO4 batteries are very resistant to abuse, such as overcharging, over discharging, and mechanical shock. They are also less likely to catch fire or explode than other types of lithium-ion batteries."
Apr 15, 2022
11
27
Swift Histyle 640
Mine was one of the KS ones that were recently recalled
Lenny HB
53,821
151,564
On the coast in West Sussex
Hymer B678 DL
You won't need one as LiFeP04 don't combust or catch fire.
That was down to faulty wiring inside the battery, the battery cells didn't catch fire it was the wiring & the case, it could of happened with any type of battery and would have been worse if it was a Lead Acid battery.
Jul 29, 2022
520
914
Don't try this at home, 03:16:
Yes extreme abuse but LiFeP04 will burn.
Apr 27, 2016
6,903
8,045
Manchester
A class Hymer
Since the 80s
The problem is that some types of lithium battery produce their own oxygen to contribute to a fire. So smothering, covering with sand etc has no effect. The heat causes more oxygen to be produced, and the whole thing gets out of hand, in a process called thermal runaway.
That's why you need a special extinguisher to seal round the whole battery and reduce the temperature. Batteries found in laptops, phones, ebikes, escooters and most EVs are this type, subject to thermal runaway.
However there is one type of battery that doesn't produce its own oxygen when damaged, and that is Lithium Iron Phosphate (LiFePO4). That's the type that is always used in motorhomes. Obviously it can have problems, like any concentrated energy store, including lead-acid batteries. But there's no spectacular thermal runaway fire if it's slightly damaged, like other types of lithium battery.
May 11, 2022
269
613
Castle Bromwich, Birmingham, UK
Peugeot boxer
Started self build December 2020, finished April 2022
Lucky escape
Lenny HB
53,821
151,564
Hymer B678 DL
Very exstream, shorted out then puntchered twice not something that's going to happen in normal use if it's installed correctly.
Considering the exstream circumstances not a very big fire, do that to a standard LiIon battery you would have a big bonfire.
Jul 6, 2009
1,826
2,266
We have2 x 100 Transporter Lithium batteries one under each seat. For extra safety they are each wrapped in a Kevlar shroud. If a fire develops just get out motorhomes are replaceable lives aren’t
Jul 29, 2022
520
914
Who known what scenario will play out, it is important to understand the facts/potential.
The shorting out resulted in no reaction so it is just the puncturing that caused the fire.
There are other demos, more realistic of accidental drilling into the battery, multiple times so maybe not real like but it burns.
Just wanting to ensure poeple have the correct information and "You won't need one as LiFeP04 don't combust or catch fire." is not.
"not a very big fire" but big enough to set light to other things.
My 105ah Lead Acid will NOT burn..
scotjimland
2,429
10,624
A Woosh bang
yip .. most fires start small..
a London tower block was tuned to ashes by an electrical fault in a fridge freezer..
The Grenfell Tower fire - which led to the deaths of 72 people - was most likely started by overheating within a Hotpoint fridge-freezer, a public inquiry has heard.
A photo of the small wire connector which is thought to have overheated and started the fire was shown to the inquiry on Tuesday.
May 7, 2016
7,319
11,843
West Sussex
Malibu Van 640 LE K
Since 2003
But it can give off hydrogen gas which is very combustible. They also contain a dangerous concentrated acid. As already said any concentrated energy store has its risks. On my personal scale of stored energy to worry about the propane gas and lead acid battery feature higher up than LiFePO4 and the diesel tank.
Jul 29, 2022
520
914
Unlikely hydrogen gas given off will reach sufficent concentration to burn, and at 29-32% acid concentration I have 99% acetic acid (vinager, to remove lime
scale. Though powdered acetic acid works just as well with out the smell) that will do more damage.
Agree everything comes with a measure of risk.
