- Oct 18, 2012
- 1,413
- 34,837
- Sold
- Motorhomed for almost 7 years - now going nowhere!
Once you have the holding positions of hook and yarn, any variation of crochet stitches depends on how many times the yarn is wrapped over the hook before or after inserting the hook.
Let’s get started shall we.........
Hold the c/h in your right hand between thumb and third finger (like holding a pen) and insert hook into loop of slip knot. Hold the short end with little finger of r/h and catch hold of ball thread with the left hand. Weave it around fingers to secure the yarn - and to keep it taut. The forefinger of the l/h does all the work of directing the yarn.
Ready to go?
Thread taut ? duck under the ball thread left to right and back across c/h right to left and pull through slip stitch
- releasing the short end and holding this between thumb and finger on l/h means you now have control and as you create more stitches you can move the thumb up the chain to keep it flat and avoid twisting.
Repeat the ducking to make another chain and keep doing this until you have a rhythm and the yarn flows through your fingers.
If you make a mistake just pull gently until you get back to a loop and carry on.
Phew! If you get the chain going then we’ve cracked it and the following instructions will be a piece of cake. Just ask if you need help.
I have found that if you hold the tail in your r/h little finger and back to the l/h thumb it keeps it steady.
Ready to go?
