LAS 1218 auxiliary charger (1 Viewer)
Jul 4, 2021
16
4
Bristol, UK
Hymer B614SL
since 2020
Hi,
I want to increase my battery capacity and I’ve been told the EBL 101 charges at 18A and that I should limit my battery bank to 180Ah (ish) as an larger will put too much pressure on the EBL.
I’ve been recommended a LAS 1218 as an auxiliary charger if I go with a bigger battery bank.
Looking at the wiring, it just seems to be a sort of kettle lead to the EBL101 to the LAS 1218. If anyone has fitted one, is it really that simple or am I missing something?
Thanks.
Aug 18, 2017
124
235
SK10
My Hymer came with a second leisure battery and the LAS1218 aux charger. The LAS is powered via a kettle lead and connects to a socket on the front of the EBL.
a900ss
Jul 4, 2021
16
4
Bristol, UK
Hymer B614SL
since 2020
So if I get a LAS1218, it’s just a 2 minute job to connect once I’ve located it in the van then? Thanks.
Lenny HB
53,793
151,461
On the coast in West Sussex
Hymer B678 DL
Yes, providing you have space to fit it.
Do you really need it, also if you plan on going to Lithium in the future you will need a new charger.
Aug 18, 2017
124
235
SK10
My installation. LAS connects to block 7 on my EBL. Looks like there’s a temperature sensor wire there too.
Apr 27, 2016
6,901
8,043
Manchester
A class Hymer
Since the 80s
Don't forget to set the charging profile on the LAS 1218 with the small DIP switches, so it's the same profile as the existing charger.
