Larger toilet seat? (1 Viewer)
gdhgdh
38
11
Dethleffs Adv 2006 i6501b
Dethleffs Advantage
Hello
Our van has a Thetford C2 fixed loo. Does anyone know of a kit which would allow the (very small!) seat to be closer to the size of a regular domestic loo?
Gavin
Apr 29, 2009
1,208
748
West Sussex
Burstner Nexxo T740
since 2008
We have a riser fitted to ours which makes it higher and as its designed for household use is the same size as ther one indoors.
Available from Mobility Outlets just google toilet risers. Ours is a Savannah with a lid.
gdhgdh
gdhgdh
38
11
Dethleffs Advantage
Ah wow I hadn't thought of risers. That's a great angle to explore, thank you!
gdhgdh
gdhgdh
38
11
Dethleffs Advantage
Height is also an issue for both of us, hadn't even considered risers were a thing.
My original question was really about width since, to quote Queen in 1978, 'fat bottomed girls you make the rocking world go round'
So I think the combination of a riser together with some other accessibility aid might be the answer here. I'll have a look and report back if I find anything decent.
gdhgdh
gdhgdh
38
11
Dethleffs Advantage
Hm, I tried this clip-on one, and it was far too big to get even close to fitting inside the loo: https://www.manageathome.co.uk/pd/novelle-clip-on-raised-toilet-seat_11371 - when you say 'Savannah with a lid' is it this one with the screws at each side? https://www.manageathome.co.uk/pd/savanah-raised-toilet-seat-with-lid_11291
Did you have to remove the existing seat from the C2 bench first?
Apr 29, 2009
1,208
748
West Sussex
Burstner Nexxo T740
since 2008
gdhgdh apologies I didnt realise it was for a bench seat. Ours is the pedestal type = it has the screws each side but I had to tape some wooden extenders to it to make it fit and I took the exisitng seat and lid off.
Oct 12, 2009
10,734
23,786
A Class N+B Arto 69GL
Since 2009
Toilet thread I seem to have missed.
I am surprised at some of the problems encountered.
I do not know what a 'bench seat' is
We have a bowl that will swivel to any desired position. As for seat height and size it just seems like ours at home. I thought all MHs had the same.
Please educate me, i.e. I need toilet training!
Geoff
gdhgdh
gdhgdh
38
11
Dethleffs Advantage
Geoff
Hey Geoff - the name's really simple once you see a picture - the C2 bench loo looks like this:
There's no swivel seat - entirely fixed. The seat itself is relatively small:
Our MH is 2006 so I'm guessing that the newer ones are nearly the same size as a domestic plumbed toilet. The small seat is quite literally a pain in the ar*e!
Feb 19, 2018
4,968
85,707
EAST ANGLIA
Murvi Morello
Since 1975
I thought bench seats were the 'norm' especially in caravans, until quite recently?? I wish my van had one, as I find the pedestal ones far too high!
Changing it is on my to-do list! :unsure:
Oct 13, 2016
1,053
897
Grays - Essex - UK
Mercedes Hymer B680
Been moho’ing for a time now
The type in the picture look more like the ones I saw In Auschwitz
Apr 27, 2008
11,851
14,093
Eastbourne East Sussex
Hymer low profile
Since 1972
It's many years since I had a C2 bench type, but seem to remember the tank was a lot bigger than my present 260 which fills up fast. Could be aging memory of course as in size of wagon wheels (biscuits)
The Coops
1,828
34,570
The Fylde
Adria Compact DL
Yes, thank you
Are they catchin their poop on a spoon and puttin it in the water?😱
Nope they are sponges, they wipe their behinds and wash the sponge in the water for the next user. No panic buying of toilet roll required:giggle:
Oct 12, 2009
10,734
23,786
Since 2009
Thanks - I said I needed educating.
I had never seen one probably because when I started looking or a MH I only looked at 'A' Class, as I had not come up the tent/caravan/coachbuilt route - I just hopped over the gunwhale from a boat.
But why is the bench twice the width of the seat? - seems a lot of space needed.
Geoff
Oct 13, 2016
1,053
897
Grays - Essex - UK
Mercedes Hymer B680
Geoff
I personally think your talking a load of S**T:cautious: ;) :LOL: (y)
Minxy
32,700
66,735
E Yorks
Carthago Compactline
You're correct the bench seats ones do have a much larger capacity however that also means you need to eat more spinach in order to lift them over the disposal point!
:giggle:
It's actually a very good design especially in combined toilet/shower rooms as you don't have any gaps at the sides which need moping up and as I mentioned above a larger cassette too.
Oct 12, 2009
10,734
23,786
Since 2009
In post #11 what are the two caps for, either side of the seat?
I can see the cassette is a bit deeper than normal. I assume still accessed through outside door.
But are we talking history now or do some manufacturers still fit them? If so caravans and/or MHs?
[Got to keep a 'toilet thread' running]
Minxy
32,700
66,735
E Yorks
One is meant to hold the toilet roll, the other is the knob to open the flap as they don't have levers.
Apr 27, 2008
11,851
14,093
Hymer low profile
Since 1972
They also came in left and right handed versions so the hatch could be at either end. I thought they were a great design but obviously I was a lot younger then to hump the tank about. They also had a bogroll holder.
gdhgdh
gdhgdh
38
11
Dethleffs Advantage
Geoff
Oddly this is indeed an A-Class, tho again it's 2006 so perhaps the market was a bit different. The width is fine and as others have mentioned, means the cassette can be bigger and there are no gaps to get wet / mouldy.
The original problem was one of seat size + height. Now that I've removed the loo seat + lid, I've been able to much more easily fit the replacement I bought: https://www.manageathome.co.uk/pd/novelle-clip-on-raised-toilet-seat_11371
I just need to cut a section out of it so the toilet roll holder can fit again, and we're all ready to accommodate The Larger Figure (y)
Feb 19, 2018
4,968
85,707
EAST ANGLIA
Murvi Morello
Since 1975
I think, where the 'toilet roll holder' is, there used to be a manual pump that one pressed down. Are they now electric??:unsure:
gdhgdh
gdhgdh
38
11
Dethleffs Advantage
Ah that would make sense. Yeah it's the usual 12V cheapo Whale GP1002.
When I first got the MH, the pump stopped working soon after and it took me a while to figure out there were two fuses - one beside the waste cassette and another on the Elektroblock.
