It was all going so well..... (1 Viewer)
Nov 6, 2021
100
112
Horsham, UK
Carthago C-Tourer
Newbie
So, MH are ready to go tomorrow, just went to rinse a spoon in the sink and no water. It woul now appear the water pump is not running. There is water in the fresh water tank (about a quarter) and it was all working fine this afternoon. The switch is on at the control panel and I am still on hook up.
Have checked fuse and that looks ok?
Apart from my water pump gone, has anyone got any ideas?
In case you've forgotten it a C-Tourer I 150 year 2018.
Going to post this in the general questions area as well as it looks like my fist trip is going to have be cancelled if I can't get this sorted tonight.
G
Nov 6, 2021
100
112
Horsham, UK
Carthago C-Tourer
Newbie
Have you checked the water hasn't dumped due to the cold weather opening the boiler relief valve,IE check under the van to see if there is a puddle. (y)
Nope all good. No water under van. Apparently we don't have one of those releif valves.
Lenny HB
54,165
153,029
On the coast in West Sussex
Hymer B678 DL
Is the pump running and no water coming out or is the pump not running?
If its not running check to see if you have 12v at the pump.
If it is running its probably an air lock. Open a couple of taps just enough to get the pump running and leave for 5 to 10 min that will often clear an air lock.
Yes you do.
P Bentley
88
306
Challenger 250
I
Have you "changed" the fuse.
Have you checked other water outlets shower, wash basin?
have yopu checked elec connections to the pump are secure?
Contingency plans
Have you contacted an auto electrician in the area to se if they can have look ?
Have you checked the nearest availability of a replacement pump on line or local to you NH supplier/dealer ?
Feb 19, 2018
5,097
86,688
EAST ANGLIA
Murvi Morello
Since 1975
I presume you have checked all the taps and it's not just the one thats not working??
strange that it was working earlier and now just stopped, you haven't disturbed any wiring connection when you were loading have you??
PS. You haven't nicked one have you because, according to your Avatar, you don't own one yet?? :rofl:
G
Nov 6, 2021
100
112
Horsham, UK
Carthago C-Tourer
Newbie
Yep, chcked all taps, even the toilet.
Spent most the afternoon messing with TV and Sat Nav so fairly sure I haven't disturbed anything.
Have amended my avatar details now, although if I had knicked this one I would jave taken it back by now :LOL:
G
Nov 6, 2021
100
112
Horsham, UK
Carthago C-Tourer
Newbie
I
Contingency plans
Haven't changed the fuse. When I turn th pump button on at the control panel I hear a click from the rear of the MH, but no pump.
Checked all other water outlets (including toilet)
Don''r know where the pump is (I'm new to this MH lark). But it worked fine when I turned it all on this afternoon. Checked everything, shower, toilet, WC basin and sink.
If there's no 'secret' button I've accidentally hit or some magic reset button then I think it's back to the mechanice at Reliance. They may take pity on me and squeeze me in :rolleyes:
G
Nov 6, 2021
100
112
Horsham, UK
Carthago C-Tourer
Newbie
Yes you do.
Pump is not running. There is a click from the rear of the MH was I hit the pump button on the control panel.
Don't know where the pump is.
Asked the dealer at hondover time if i had a frost relief valve and he said no.
What I have found is another fresh water cap in the garage (as well a the one I've been using at the bottom of the bed). I opened it and water came out, so put it back quickly). The water tank is abot a third full.
Sep 10, 2017
653
727
North Brum
You will have an auto "dump valve" LHS in the big locker by the hab door. One is blue and that dumps the water if cold and the other is a brass lever to empty the boiler. Pump is likely to be the uk offside in the front locker, behind passenger seat. With 12v and pump on the panel you should get a continuous 12v supply to the pump. Good luck.
two
Aug 4, 2011
4,913
4,582
West Midlands
A-Class Fiat
I'd expect your pump to be under the floor, and accessible by removing a floor panel or opening an outside locker.
You need to find it to be able to test it. Your description of a 'click' is interesting - it could be from the (jammed?) pump, so I'd go looking to see where that sound is coming from.
Jun 4, 2010
393
785
Try tapping the pump ,it might seized during wintr
Feb 22, 2016
3,654
11,159
York
Bailey 620 Approach
Since 2015
Don’t know about your particular van but in our van, if there’s less than about a 1/4 tank of fresh water, pump doesn’t operate. First happened to us in Portugal. We added water and bingo! Others have suggested similar.
Oct 29, 2016
4,535
53,818
Surrey
Carthago C Tourer
You do have a frost dump valve, its under the floor of the hatch as you come in the hab door, next to the boiler drain off dump valve.(y)
The click you hear from the rear is probably a latching relay inside The CBE Consumer unit when you turn on the control units 12Volt supply, which is a good thing.(y)
I am surprised you dont know where roughly the water pump is as they are loud, I nickname ours "The Wood Pecker":giggle: ours is visable and easy to get to from one of the external lockers. It maybe wise to check the water filter (clear plastic bottom unscrews) to check if any crud has been captured, however this is unlikely to be the cause of the pump not working, just good maintenance.
You have a pressurised water system (no micro switches in taps like Hymers) once you turn on the pump at the control panel, the pump usualy kicks in momentarily to pressurise the water system, once you open any tap the pump should run immediately.
If it doesn't then you need to locate the pump, find the fuse for it in the distribution board in the garage, check the fuse is OK.
The pump is a Shureflow type, and is normally very reliable, but if you have a multi meter, its easy to check that 12V is getting to it, if not, you have a supply problem, probable cause blown fuse.
Lenny will sort you out, no problem.(y):giggle:
Good Luck.
LES
G
Nov 6, 2021
100
112
Horsham, UK
Carthago C-Tourer
Newbie
Thanks for all your help everyone. Thanks to the advice on here it's now working. :giggle:
Found the water pump thanks to the advice on here (it's in underfloor area behing a mesh cage), then gave it a little tap with hammer and hey presto, it works, and yes it is fairly loud :) . We tapped various parts of the pump, but it only seem to work when we tapped the bottom (black plastic) bit of the pump.
So, hammer has been packed, and off we go.
Thanks again for all your help.
Southdowners
3,358
25,318
West Sussex
Concorde Charisma
Since May 2015
Glad everything is ok now… have a good trip!
138go
3,276
14,614
Carthago 138
Since 2001
If all else fails, belt it one!
There is a pressure valve, on top of the pump. When the pressure drops it starts the motor. You need to check whether there is 12volts to the motor. Also check the ground cable to the pump, as without a connection the pump won’t work. Have a look online for a Shurflo pump wiring diagram.
Sep 19, 2016
696
15,909
romford
rollerteam 259p
owned vw in 90's just purchased rollerteam
Now I have very little advice to give where Motorhomes are concerned. I was the same as you, but your handover I guess was basic, I would try and find all the bits that you might need to find over time.
Lenny HB
54,165
153,029
Hymer B678 DL
The black plastic part of the pump houses the diaphragm & the microswitch, as the pump was not running I think the microswitch was probably sticking. Might be worth carrying a spare microswitch.
Feb 19, 2018
5,097
86,688
EAST ANGLIA
Murvi Morello
Since 1975
or pump as they are only £60-£70 and, normally, easy to fit?
two
Aug 4, 2011
4,913
4,582
West Midlands
A-Class Fiat
Glad you found the pump. It may have an integral pressure sensing switch and that had stuck.
I'd get a spare pump. If you keep on hammering it, you're going to need one.
Sep 3, 2012
7,638
26,275
Cheshire
C Class Elddis 175
8+ years
You may need to clean the pump out to stop it sticking again. (y)
Not a difficult job but make sure it's turned off first ;)
G
Nov 6, 2021
100
112
Horsham, UK
Carthago C-Tourer
Newbie
So, I'd decided to follow advice and get a spare pump (although the original was fine after the hammer 'repair'). This one looks to have the same settings as mine (12 volts, 7.0 l/min, 1.4 bar, 4 amp). Do I need to get any other parts in order to fit it?
