Is this the dump switch ? (1 Viewer)
Dec 8, 2018
46
16
Bessacarr e435
1 year
Hello....trying to identify dump switch.
Is this it ?
If it isn't where do I find it?
Pump not supplying water to taps, works ok....
At present am using a flask to get water from the water tank as pump just scooted water out of the bottom. If this is not the dump switch then where is the effing thing??????
Swifter
3,916
9,055
Herefordshire, UK
Since 2019
This will dump the water from the boiler. Lift up the yellow level and the water will run out of the boiler
Apr 3, 2018
3,697
10,280
PVC
1995-2004 & 2017》
Yes boiler dump valve in closed position
Oops Swifter got quicker fingers than me.😎😎😎
kevenh
3,319
11,801
Thatcham
Compass C-Class
I'm a Progressing Newbie
That’s a match for the manual dump valve fitted near our truma water heater 👍🏻
edit: sorry, reading the whole section. There is also an automated dump valve option for truma WH. That dumps below 5decC. Iirc
How warm is your MH?
I don’t have that option so can’t advise on how to close that one. A clothes peg?
george mcneill
Dec 8, 2018
46
16
Bessacarr e435
1 year
Ok so the switch is in the position to work without any water draining away....and I should be able to work the taps ?
It has 3 positions...when vertical that's when it will drain ? TIA.
kevenh
3,319
11,801
Thatcham
Compass C-Class
Yes, upright is Open and the water heater drains
george mcneill
Dec 8, 2018
46
16
Bessacarr e435
1 year
Just discovered a leak at the augur....any advice on fixing that? Sealant etc ?
Jul 5, 2013
11,742
13,735
Since 2013
That is a manual dump valve and it is closed, so has not dumped any water. It will not open automatically, as others have said, you have to lift up the yellow bit. If the pump is dumping the water look underneath and see where the water is coming from, that will give you a good indication of where the automatic dump valve can be found inside the motorhome.
Lenny HB
53,718
151,062
On the coast in West Sussex
Hymer B678 DL
No that is just a drain tap.
Dump valves/switches are like this:
This is the current one that has been in use for about 12 years or more and is mechanical.
This is the older type and is electrical needs 12v power to stay closed.
Dec 2, 2019
357
1,712
Redcar/Cambrils, Spain
Now Tugging
More with boats than Moho
If it is this type there is a reset button on the side that needs to be pushed in to reset whether the valve has opened automatically on low temp or opened manually
Lenny HB
53,718
151,062
Hymer B678 DL
But the yellow lever does drain/dump the water from the boiler , it just needs to be activated manually ?
It is just a drain valve the others are frost protection valves that dump the water if there is a danger of freezing so are often referred to as a dump valve.
Lenny HB
53,718
151,062
Hymer B678 DL
The mechanical one to reset you push a blue button at the bottom on the back and turn the knob on top 90 deg to latch it. You can do a manual drain by turning the knob on top 90 deg.
Lenny HB
53,718
151,062
Hymer B678 DL
Cheers Lenny . Can these auto dump valves be retro fitted ?
Yes but they ain't cheap over 100 quid, there are different versions depending on the plumbing, i.e. flexible or semi ridged pipework.
Dec 2, 2019
357
1,712
Now Tugging
This is the valve in the "manual" dump position
This is the valve in the "normal" position but reset button not pressed in, ie, will still dump water
This is the valve in the "normal" position with the reset button pressed in
Aug 26, 2008
4,774
25,110
B&NES
Van Conversion
since 2007
Great to see pics of the Truma dump valve. Mine is completely hidden. :banghead: I can just about reach it and fiddle with the knob and push button until the water stops splashing out at which point I have succeeded, yay!
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
Drain valve same as mine. Don’t forget to close it when refilling with fresh water. Ask me how I know says him with the wet feet😂
Cheshirecat57
3,482
5,590
Mid Cheshire
None
10 years on and off
Hey, it’s not hidden, it’s your eyes out of focus due to fiddling with your knob 😄
TerryL
6,194
8,208
North East
Low Profile
Guys, guys guys!
The OP said he can't get any water to the taps in his first post.
Then later he says the pump is leaking.
Doesn't ANYBODY think there just maybe a connection.................????? Martin tried!
The dump switch, lever, button, whatever is a red herring!
george mcneill get the pump sorted first, will almost certainly solve your first problem.
Swifter
3,916
9,055
Herefordshire, UK
Since 2019
Guys, guys guys!
I asked the OP to show us a picture of the pump in post 13. No reply yet 👍🏻
