Improving TV Sound for Rear Lounge Viewing (1 Viewer)
Apr 24, 2021
53
78
Sleaford, UK
Low profile coachbui
Since 2019
Our TV is mounted midship so can be viewed from rear lounge or front dinette, however that means if using rear lounge we tend to need the volume a little high, which generated a mild complaint from a nearby camping couple one hot evening when windows & doors were all open
I’ve installed a pair of small speakers in the rear lounge area which plug into the TV headphone socket, however whilst working I’m not getting sufficient volume from the speakers
I’m sure there must be someone on here with a knowledge of electronics & speakers, all joints were soldered and not dry connected
Jan 13, 2014
3,621
11,626
Leeds - Yorkshire
Sound Box you can connect to TV via Bluetooth and have it next to you if you wish.
Gellyneck
9,274
18,430
Scotland
More than toes wet now!
5,956
39,443
Uk
We bought one of those but sent it back, didn’t like the sound at all.
Bluetooth can have a delay unless using a Firestick where you can adjust the latency.
3,621
11,626
Leeds - Yorkshire
Yes, l wasn’t suggesting this model it was a simple example as a answer to the OP’s problem, you get what you pay for.
Excaliber
Apr 24, 2021
53
78
Sleaford, UK
Since 2019
Thanks all for suggestions, not sorted yet but going down the route of installing a 12v amplifier to drive sound to speakers
9,855
20,323
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Gellyneck
9,274
18,430
Scotland
I'm thinking about one of these to improve the sound quality.
Do you know what voltage they operate at please and can they be left permanently connected to power ?
Thanks 👍
The unit is charged by a USB A to USB C cable that is supplied however you need to provide your own 230v plug with USB output.
The alternative is to either use a 12v step down or plug it into a USB socket on the TV (this is what we will do).
They do not recommend the unit is left permanently charging as with all L-ion batteries it can shorten their lifespan.
The manufacturer advises a 24hr usage on one a full charge but .........? When on battery power it will automatically switch off after c30 minutes of inactivity.
If you are interested in the Soundcore 3 Amazon have refurbished units with a 12 month warranty on sale a £35.89 -10% voucher https://www.amazon.co.uk/Soundcore-...nology-Waterproof/dp/B08VDRF1F2/?tag=mhf04-21
I bought one and delivery expected on Saturday.
User manual for it attached.
edit: ps there is an app available for it to make changes to various settings.
  • A3117 Soundcore 3.pdf
Gellyneck
9,274
18,430
Scotland
The unit arrived on Saturday and it took a couple of minutes to download the app, connect it to the laptop (and mobile) and set it up. Despite being refurbished it does look like new!
I know it's only a day or so but quite impressed with it. Sound quality is very good (considering it's physical size) and no apparent time lag.(y)
Overall, seems to be well worth the money.
