Has anyone any experience of the Hymer smart battery system, either as a retrofit or as original fit.
I am considering upgrading my 2 off 95ah agm batteries to cope with ebike charging while off grid.
Jon
LennyHymer Smart Battery System is just what they call their LifePO4 option, do it yourself and save over a qrand or two.
The B2B charger i think just a buck booster (sort of) so it can take the lead acid volts and dial it up or down to suit the Lifep04, that is what I meant in my previous post, the B2B charger basically isolates the two battery types from one another so you can have entirely different charging regimes for both batteries.Andy
The blurb says that the agm stays charged and is only used when the lifepo4 is insufficient, or as battery heaters before charging the lifepo4 if the temperature is too low
My doubts are around the correct charging for the two battery types.
Jono did some testing on this on his narrow boat and at tickover with a high amp alternator he could charge his Victron 300 ah batteries in 88 minutes....(from 50% to 100%)Maybe I have used the wrong term for the Votronic box that sits between the engine alternator and the hab. battery and can deliver up to 45A charging current.
Whilst this setup does work with 2x 95Ah agm batteries, I feel that the Agm will not accept the max rate of charge, before reducing it.
Lifepo4 will accept this sort of rate so making short drives more likely to put adequate charge back in.
The addition of ebike charging ca 500wh per day, and short journeys will strain the electrical system.
Your B2B is fine. The Votronic has a lithium option. If it doesn’t have a temperature probe you’ll need to fit one - simple to do and not expensive (it’s in the manual how to do it).Lenny
I wonder, to just install a lifepo4 battery would mean a new b2b , solar and mains battery and a battery monitor all with lifepo4 settings.
Straight forward enough, and maybe simpler than adding it to the existing agm setup which is anyway 3.5 years old.
The dilemma will then be whether to go for a simple lifepo4 without internal bms, and have an external bms set up slightly conservatively for vmax and vmin, or use an internal bms.
My action plan is to do the same thing. I did the same thing in our last Hymer. I see no point in keeping any heavy AGM batteries. The Sterling LiFePo4 batteries and B2B work very well and are so much lighter.I settled on replacing the AGM battery pack, which was 3.5yrs old and unwilling to run the ebike chargers, with 2 off sterling 100ah LiFePo batteries.
Just by way of an update for anyone else with the same query as I, here is the response from Hymer technical support.Hello. I just found this thread on a search, as scouring the Hymer manual yielded nothing. My question is - is it okay to leave the smart battery system in EHU whilst in storage? There is a significant, and fairly rapid (vehicle battery getting critical), deterioration of the battery condition if l leave it off the EHU after about 4 weeks. There is150w of solar on top, but we are under cover with no dire t such light. Any help would be greatly appreciated.
Thanks.
