- Oct 17, 2023
- 111
- 128
- Fiat Based Hymer
Interesting, because the thing which I do not see is the light.I don't see how just the dip can fail.
Thank you for that.There has been a problem with headlight looms failing causing lighting problems.
I have a 2018 Exsis i588 and my offside indicator failed.
This was caused by the Hymer wiring loom failing.
I purchased replacement upgraded looms from The Lazee Camper.
The only way to test is to disconnect the loom and run a continuity check.
This may be the problem. Hope it points you in the right direction.
What about main beam?Interesting, because the thing which I do not see is the light.
I might try that when the weather dries up. Not a job for a rainy day. But, I will have a look at the loom first.I purchased replacement upgraded looms from The Lazee Camper.
As there is only a single bulb so it's not a bulb or fuse.With the headlight flash control operated, both headlights come on main beam, regardles of any other setting.
Indicator and DLR OK on botth sides.Does look like a loom problem not the normal fault when it's a loom (that's indicator and DLR not working).
That sounds like a plan.If the rain ever stops swap the looms over & see if the fault goes with it. Left & right looms are the same.
Less encouraging. But thanks for the info.The connectors are a right pig to get off the ballast units, the insulation breaks down on the loom wires and the copper wire corrodes & breaks.
