Hunting for a Hymer (1 Viewer)
chazncaz
4
Hunting for a Hymer
We aren't new to motorhomes & campers but a Hymer will be a new venture for us. Budget suggests that we are looking for an A Class with drop down bed from between 1998 and 2004 dependant on mileage and condition. We would be really grateful for a steer as to the model ranges from this era. What we want to avoid is having to make up a bed every night from seating cushions which we find uncomfortable (and a faff!). The van will ideally have an awning, solar panels and less than 200,000kms on the clock. TIA.
cliffanger
4,911
34,373
Saltford
Hymer A class
Since 2013
We had a B564. Ours was 2006, but it was a beautiful van. Huge back bathroom, drop down bed, and brilliant fresh water and waste capacity.
cliffanger
4,911
34,373
Saltford
Hymer A class
Since 2013
This one is an older version of the one we had, but same layout.
Mar 21, 2022
163
293
Bradford, UK
Chausson 711
Since 2009
Could you give me an idea of your budget?
I have a friend who may be selling a Hymer Starline 700 2005, very low mileage.
I am unsure of what he is selling it for, but could enquire if you let me know your budget.
Jan 12, 2020
232
751
Burstner i681
Since 2018
We were in your position 5 years ago. We looked at the Hymers mentioned above but finally went for a 2004 Burstner i681 Elegance which is slightly bigger than the equivalent Hymer B544/584 etc. Might be worth a look.
mikebeaches
5,420
8,720
Bristol
Rapido V68 Van Conversion
Since 2009
dawsey has a fully-specced 2002 Hymer B544 for sale in the classified section on here:
Feb 18, 2022
152
149
Suffolk, UK
Rapido 9048DF 2016
We used to have a B544 2002.
Lovely van but started to suffer from electronics rot (as they are prone to) so we decided to part company and changed to a Hymer caravan.
We have since learned that it is feasible to replace the whole wiring loom which would almost certainly have solved our problems.
However be aware that early 2000 vehicles are getting a bit long in the tooth and most commercial Fiat garages won't have seen one for 15 years or more, which is well past the length of service of most of the mechanics.
So - best of luck, there are some lovely examples, but be prepared for things to wear out.
Dec 17, 2016
982
1,010
Malvern
Hymer B525 2006 A cl
We have a B525. 2006 on the Merc 2.7L chassis. . Works well for us as it has garage with a bed over as well as a double drop down bed. It's well built and has aged well. There can be problems with the garage floor rotting. Rear mudflaps help
For info generally models ending in 0 or 5 are based on the Merc chassis and the rest on fiat. The first number gives some idea of length in meters but it's quite variable. So ours with the 5 is 6.3m. The equivalent fiat version is the B524. The B700 mentioned above is probably about 7m long on the Merc chassis.
Good luck.
mikebeaches
5,420
8,720
Bristol
Since 2009
he was supposed to be withdrawing it as the campsite fell through & they have to live in it still.
Interesting - I knew the deal for the campsite was 'at risk', but didn't know it had actually fallen through - so thanks for the info! (y)
Mar 22, 2023
638
1,755
New Forest, United Kingdom
N+B Arto 74C
B644 with the 2.8jtd, the things are total work horses, you will not be disappointed if you look for a nice one.
