Couldn't see anything on their website and was planning to call them tomorrow. Thanks anyway.Link Removed may be able to help.
Very different!Make sure you get the right one this is my 650 oneView attachment 635304
Cheers, that's really helpful. Shame they make it so difficult to remove them. I'll try what you describe. Hate to think what a new one would cost.If I remember correctly that's the same bumper end cap that was on my G74O.
With the long screw removed from the top hat fixing I recall that on mine the end cap was attached to the middle section by plastic spot welds. I used a bit of hacksaw blade to carefully cut through the welds, then unclipped the bottom corner of the end cap from the side sill and gently wriggled it until it came free. If it seems stuck, look for a sikaflex type blobs of sealant along the top edge and if necessary cut through to loosen with a long bladed craft knife.
I repaired mine, along with one of the side sill sections by using JB Plastic Weld and for the missing bit you could bond in a bit of white plastic modelling sheet. It wasn't too bad a job to do and once the surface was rubbed back, filled with stopper, sprayed and buffed up, you could not see where the repair had been carried out.
If you are going to repair yourself, the paint code for the Pilote white colour is FIAT BIANCO 210/R.
PM sent.acropolis22 if you need a replacement top hat fitting (white washer and plug) drop me a PM with your address and I'll pop one in the post as I've got a few Pilote supplied ones in my spares box.
