How to Add Amp/Volt Meter to Solar Setup? (1 Viewer)
Sep 11, 2018
324
368
N Wales nr Chester
Citroen Relay pvc
16yrs
Forgive me as Iā€™m having a day of brain fog šŸ„“
I have a solar setup at home consisting of 1 x 100w solar panel connected via a Victron MPPT 75/10 controller to a 110a 12v battery, I want to insert this ā€˜Ketotekā€™ Amp/volt meter so it will show voltage & amps from the solar panel via MPPT controller going into the battery & also show Watts & energy being used -
Can anyone please help explain how to wire this in ?
TheBig1
17,649
43,471
is there a shunt with that meter, that you wire in between the power source and load (battery)? Some do and this measures voltage and current. Others have just a 12v supply to power the meter and 2 terminals that just attach across the battery and estimate the wattage
TheBig1
17,649
43,471
You are looking at the supplied diagram of how to wire 4 meters. You just need the one in line with the solar
Apr 27, 2016
6,895
8,034
Manchester
A class Hymer
Since the 80s
I can't find info on that model (KT D132), I can only find info on the KT D138, which has an external shunt. That's a strip of metal with two large terminals at each end, and two smaller terminals next to them. If you don't have a shunt, probably your model has an internal shunt. Your device with its internal shunt should be put in the wiring from the solar controller to the battery.
If for example you are mounting it near the solar controller, you could disconnect the wires from the solar controller, and connect them to the outer pair of terminals, making sure the positive and negative are the right way round.
Then run a couple of new wires from the solar controller to the inner pair of terminals, again ensuring the positive and negative are the right way round.
That's according to the diagram on the back, and also some diagrams of items that look like clones of your model.
Sep 22, 2023
455
368
4 berth coachbuilt
That is not a usefull way to measure the energy being used.
For a usefull system you need to measure the voltage and TOTAL current into and out of leisure battery, not just the solar panel currents
The NDS Energy Meter from RoadPro is one such device and it's shunt is connected in the positive lead from the leisure battery. It works extremely well showing the voltage and SoC (State of Charge) of the leisure battery, together with TOTAL current (amps) into or out of the battery.
Note that this particular unit currently only works with lithium LiFePO4 batteries.
To work properly, all chargers and loads need to be connected via the shunt. It will deal with currents upto 150 amps.
May 11, 2022
262
595
Castle Bromwich, Birmingham, UK
Peugeot boxer
Started self build December 2020, finished April 2022
Does the solar controller have a Bluetooth connection, sure it does. Get the victron app and connect, it will give you all the information you need on the app and more tbh.
Then do what LithiumConvert has suggested and connect your shunt to the negative terminal on the battery and all your negative battery cables to the otherside of the shunt.
Sep 22, 2023
455
368
4 berth coachbuilt
Then do what @LithiumConvert has suggested and connect your shunt to the negative terminal
Unusually the NDS Energy Meter shunt is on the positive terminal on the battery.
Do read the instuctions on whichever one you choose.
Sep 22, 2023
455
368
4 berth coachbuilt
Also, you can choose whether you want a nice physical display like the NDS has or whether you want a meter with a moble phone bluetooth app.
I like the NDS display.
May 11, 2022
262
595
Peugeot boxer
Just have to make sure the fuse is first then the shunt, very unusual, wonder why?
May 11, 2022
262
595
Peugeot boxer
A fuse should be the first component in the circuit from the live terminal of the battery, if the shunt is on the live side of the battery, which is very unusual.
If the shunt gets a short/ something shorts across to the negative side (which can be the whole steel body of the van, quite a big target) then nothing is protecting the battery from........bang.
Sep 22, 2023
455
368
4 berth coachbuilt
No more likely to short out the Energy Meter than to short out a fuse mounting.
Apr 27, 2016
6,895
8,034
Manchester
A class Hymer
Since the 80s
Shorting out the Energy Meter isn't a problem - it will stop the meter from registering anything, but it won't be dangerous. The problem is any earthed metal item shorting to the terminal or anything else on the wrong side of the fuse. It's a vehicle, accidents happen, metal gets pushed into the wrong place and can cut through wire insulation. That's why the link from the battery to the fuse should be as short as possible.
If the Energy meter is before the fuse, then logically the fuse could have been swapped with the Energy Meter, so it's not as close as possible to the battery terminal. As long as there are no branches in the wire from the fuse to the Energy Meter, it won't be affected at all by the extra length of wire.
I think this problem is the reason most shunts are fitted on the battery negative terminal, not the positive. But it should work perfectly well in either position. Most EBLs, for example, have a shunt in the positive feed from the leisure battery, but it's built into the EBL, not near the battery.
Sep 22, 2023
455
368
4 berth coachbuilt
Perhaps you didn't read the original post.
This topic is about a home system .
