Hook up not charging leisure battery (1 Viewer)
Dec 8, 2018
46
16
Bessacarr e435
1 year
Hey peeps !
I have a Bessacarr E435 mh which is not charging the leisure battery at the Gatwick site I go to.
I have just switched my brain on and replaced a 15A fuse at the fuse bank near the plug in point for the hook up.
I am away from the site now, but am wondering should that do the trick ?
Hook up is capable of 16A apparently.....
TIA !!
11,955
9,164
It should work but, you could / can switch between engine and leisure charging so I would check that as well šŸ˜‰
george mcneill
Dec 8, 2018
46
16
Bessacarr e435
1 year
Yes tried that. The switch trips every time you attach at Gatwick, so you have to confirm . Aha ... just remembered it's the charging that doesn't work and so it's a relay switch problem. I need to find the relay !!
Anybody got ideas for that? Is it the one at the fuse bank?
11,955
9,164
Have you tried a different HU cable ?
george mcneill
Dec 8, 2018
46
16
Bessacarr e435
1 year
No......I am sure that's not the problem.....AC works on hookup.
I should have filled the first post with decent info !
11,955
9,164
If all Fuses ok try a car battery charger as the built in charger could be faulty
Sep 3, 2012
7,602
26,189
Cheshire
C Class Elddis 175
8+ years
There was another thread where the ehu had to be twisted at the post side slightly to engage the connection.? (y)
It was on the post titled "What a plonker"
george mcneill
Dec 8, 2018
46
16
Bessacarr e435
1 year
Am sure I have fixed it by replacing 15A fuse.
If not that , then I have 2 more relay switches to match the one at the fuse bank.
Thank for attention peeps!
george mcneill
Dec 8, 2018
46
16
Bessacarr e435
1 year
Yeh.....that was the brain dead failure....this time it's different !
Feb 22, 2020
344
1,007
West Midlands
Bessacarr E582
2011, 11.6m cruiser on Thames for 5 years before
If you have a Sargent mains box like my Bessacarr, there is a fuse at the back for the charger which you have to remove the box from its housing. It could be that this is blown or as mine just a bit corroded, needed shining ( technical term, please?) and works fine again!
