Hook up lead terminations (6 Viewers)
funflair
19,427
30,576
Guisborough
MORELO palace
since 2012
WD40 ?
The killer of all things electronic ?
It is good if you can clean off residue and renew it regularly ( about every three weeks or so ).. But general use ?
You do know that the bloody stuff becomes hygroscopic after a while and far from repelling moisture actually absorbs it !
Didn't know that?
Jaws
23,841
72,711
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
In the good old bad old days I loved the stuff ! Earned me an absolute fortune ! Folk would spray it on distributor caps in cold damp weather to help with starting.
Worked well for a while then as time went by .. no more spark ( wellllll, actually LOTS of sparks just none where they were needed !! )
I would get the call out and of course replace all the HT leads and the cap at an exorbitant charge :xsurprised::xwink:
In more recent years I have spent hours cleaning the poxy stuff off of ECU's on bikes..
If you want something that does what folk THINK wd does, look up ACF50
It is made by Lear of Lear jet fame and really does stop corrosion and keeps water out
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Techno hope that isn't Artic Blue your using, as your probably aware it doesn't have approval for use on Caravan sites with reference to the the Regs
Techno
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
WD claim to do almost everything but it doesn't have the lovely smell it used to have in the 70's 80's
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I'll not worry about that.
EDIT
according to the CC club information publication ORANGE is "recommended" only
Gorse Hill
2,364
1,944
Stretford
Why, what happens if something goes wrong when the cost of H07/5 is about the same
Remember the regs can used against you in a court of law when there looking for someone to blame
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Jaws, you beat me to it, mentioning ACF50.
Good stuff, used it on all my bikes, left out in all weather conditions.
Jaws
23,841
72,711
Thetford Norfolk
C class, Chieftain
I was the FIRST motorcycle place to sell it specifically for use on bikes way back around 2001..
I only got in to it because a guy who worked on planes recommended it..
Not gonna go into the diatribe of all the tests I did but will say that 6 months after I first got the info I became the biggest seller of the stuff in the UK to bikers.
Of course as time went by the bigger players sussed it out and instead of buying it by the pallet as I was were buying it in 40 ft containers !
Feb 27, 2011
14,778
76,363
UK
Self Build
I have both the heavy duty orange and the blue cables. If there is any risk of the cable being run over I will always use the orange. It is much tougher and more resilient than the Arctic.
Feb 27, 2011
14,778
76,363
UK
Self Build
PS: I meant to mention not all blue cable is called Arctic and not all cable labled Arctic is actually suitable for outdoor use below 5C.
I just did a search for the article I read a while ago on this subject as it can be confusing.
So when buying Arctic blue cable, please ensure that it is both suitable for outdoor use and can withstand low temperatures.
  • 2009_33_winter_wiring_matters_arctic_cables.pdf
967
3,361
Find this stuff excellent in all electrics.
Really protects connections/circuits from corrosion.
We use it all the time in the workshop.
Daifuse
183
310
Milford Haven
c class
Since 2011
I've used 'FOSPRO' for years. First experience was during my time in the Navy, (FAA) to get rid o f condensation on electronic equipment in aircraft, particularly Buccaneers where the radio bay was in the fuselage and unpressurised. After flight, the condensation on the gear was incredible inside the covers. Due to extreme changes in altitude an thus temperatures I would think.
Aug 6, 2013
11,958
16,575
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
WD40 ?
I didn't & haven't observed it happening although I hate the stuff sprayed all over ignition systems - it attracts dirt. Then it really is hygroscopic :D
