Help I've done something !! (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
The cupboard which holds the ehu in has a light which was not needed and in the way so i removed it, i may well have caused a quick short.
During this i heard the CD whirring(powering down i guess) and then later found its dead aaarrrgghhh.
Its connected to the reversing camera and 10" screen for watching dvd's and doubles as the reverse camera screen all factory fit.
So the radio is dead as is the screen so thought blown fuse, checked every fuse in the vehicle without success.
I noted though the trip on the ehu (can't remember its name) had tripped so i did short something, reset that and everything works fine bar the Radio/screen which is 12v. I even pulled the radio to see if it had its own fuse but no joy.
Any thoughts on where else to look ?
2007 Renault Master base if it helps.
Dec 12, 2010
5,431
21,707
Cumbria
since 2011
When you say "all the fuses" just checking you mean the hab panel, the vehicle ones in the dash and the ones in the engine bay ? Other than a blown fuse,I can't imagine what else it could be :(
pvw10
pvw10
273
45
Gloucester
Coach built
Yes the ones on the ehu, then i checked every single one (about 40) in the vehicle dash, unable to locate any more but has to be a fuse.
Engine compartment tomorrow but from memory there all big guns in there.
pvw10
pvw10
273
45
Gloucester
Coach built
Update.
I later found the fridge was also dead and then the pump only worked on occasion so this was a major concern now as the beer could get warm !
Found under one seat some more fuses/relays that i believe control the step and fridge (amazed to find the fridge fuse here) yet they were fine bar a 20amp fuse that was gone, i replace this and...............nothing.
Last thought i unscrewed the panel covering the main wires under the ehu and wiggled all the wires and hurrah one multi plug was loose ! I pushed it back into place and every item worked perfectly again.
So note to others, ensure all the plugs going into the bottom of the ehu are firmly pushed in.
Now i wonder what that blown 20amp fuse protected............
