Help for a Bessacarr Please (1 Viewer)
Doddy999
159
14
Exeter Devon
Hi All
Just got a 2003 Bessacarr 765 fixed bed, under the bed there is a hatch I opened
(in the middle) to my horror saw a blank hole in the plastic belly tank :Eeek:
There is another one with a large screw cap, lying next to it are 5 wires not connected
& two blue pipes?
Is this where the pump should be? If so anyone know the make & model please.
This is my first motorhome so a bit dim:RollEyes:
Regards Doddy
Braunston
1,408
7
Hi,
I don't have the same model as you so this is only a guess, but have you got a small digital panel above the entrance door or elsewhere within the motorhome that controls your charging, power selection etc etc, only if you have you may find the wires could be for the tank sensors, e.g. full, empty, partly full etc that shows on the digital read-out for your electrical control system.
My pump is under/between the floor under a small hatch not sure where yours would be but mine definitely isn't in the tank,
On mine the large plastic screw cap is to allow access to the inside of the tank so as to either remove the drain bung or get access to the sensors I mentioned above
What the blank hole is I haven't a clue, other than to say my tank has 2 large plastic screw caps, Just a guess but could one of the caps been laid aside to indicate that the drain bung may of been taken out, and needs to be pushed back before the screw cap is replaced, just a thought, may have been left off as an indicator??
hope it helps.
Hi All
& two blue pipes?
Regards Doddy
Fatalhud
286
Nottingham
19 Years on and off
On my E760 the pump is under the hatch outside the wardrobe
To see what should be in the under bed hatch I would have to empty the compartment and look.
It could be the wiring and hole for the tank level sensor
If you are really struggling post again and I shall look tomorrow
One obvious question is, Have you not tried the pump
Alan H
Fatalhud
286
Nottingham
19 Years on and off
Looking at the wiring diagram the fresh water tank does have 5 wires
Alan H
Doddy999
Doddy999
159
14
Exeter Devon
Many Thanks guys,
Fatalhud yes the cables are
Orange/White
White
Orange
Blue
Green
Braunston Yes mine has the control panel above the door.
There's no threaded part on the hole to screw cap onto.
just the one cap.
wanttobeaway
55
on tour
white one
only 3.2 and counting
the bottom hole takes a bung /plug so it will not be threaded so check for a bung push it in then put some water in the tank and see if you have any problems
motownmickey
3 years
Hi All
& two blue pipes?
Regards Doddy
We have an E760
Where did you get your motorhome from? If a dealer go back and request all the paperwork / booklets / etc
If you contact SWIFT they will send you a handbook which should answer all your issues.
The lid under the fixed bed gives access to the fresh water tank. You'll need a rubber bung in the bottom, and a screw cap on top. If either of these are missing suggest you go back to seller.
Regret can't advise on wiring. If wiring is disconnected, from experience my advice would be to get it repaired by reputable company eg Essanjay in Poole
any other issues contact me directly. keep me posted how you get on
welcome to motorhoming - it's a very steep learning curve, even after three years :Confused:
regards
motownmickey
Fatalhud
286
Nottingham
19 Years on and off
Hi Doddy
Just been out and emptied all the crap from under my bed
The missing item is the water level sensor
The 2 blue pipes
1 is for the overflow this sticks out under the van
The other I would guess is possibly a vent pipe
Without this unit in place water will pour under the floor of your van, So It is a must that you either, replace with a new sensor or plug the hole
Alan H
Doddy999
Doddy999
159
14
Exeter Devon
Hi Alan
So kind of you to take the trouble for me. :thumb:
I will now try to find one, probably through Swift I imagine.
Once again many thanks.
Regards Doddy
Hi Doddy
The 2 blue pipes
Alan H
Doddy999
Doddy999
159
14
Exeter Devon
Well finally sourced one after ringing about 7 dealers with no joy in the South West.
My local one Martins of Exeter are **** they just did'nt want to know :Angry:
Ended up getting one from Brownhills, great service gave me the part No, posting today
for me £102 :Eeek:
I notice on Alans pic for me there are only four wires from unit the new one's have 5 ?
Thanks Again for all your help. I bet I will be back shortly for mor info.
Oh incase anyone else has this problem the Part Number is 1051166.
Doddy
Fatalhud
286
Nottingham
19 Years on and off
These units are notorious for giving false reading and failing, which could be why the unit was removed in the first place
My sensor has read 75% full for the last year, so don,t worry when yours fails again:Doh:
Alan H
Doddy999
Doddy999
159
14
Exeter Devon
Alan H
Alan thanks for that "NOT" :winky: So I should of just blanked it off & look at my levels?
:thumb: Doddy
baah
3
e760 bessacarr
Alan H
Hi Alan h
I’ve just brought the same as you the e760
Just wondering if you could help , what are the buttons/switches on left as you open main door, I know one is for outside light and one for step
Cheers mark
Mark and Mindy
1,031
4,813
Nr Bicester
Adria Twin 640 SGX
Since 2019
Hi Alan h
Cheers mark
This thread is 12 years old and all the other posters on it have become "free members", you would be better off starting your own thread to see if anybody knows the answer; and Welcome to the Forum!
Nov 5, 2013
3,115
98,140
Shropshire
Carthago chic e-line
Since 2013
I doubt you'll get an answer as he hasn't been on since 2010!
DJT1815
Bessacar E760
Hi Alan h
Cheers mark
The other two buttons are for the forward interior light and the rear interior light.
DJT1815
Bessacar E760
Hi Alan h
Cheers mark
The other two switches are the front and rear internal lights.
