Handy fuel map (1 Viewer)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
BRILL!! Thanks for posting that. (y)
Emmit
8,054
17,802
Cornwall
Pilote Explorateur
Jan.2014
Not wishing to be a miserable old git but how does anyone go on about getting the map improved?
For instance, the Sainsbury's just off J25 M5 @ Taunton and surely there has to be a Supermarket just off the M4 twixt Bristol and London.
Sep 10, 2013
1,187
18,750
Chelmsford Essex
Getting better
For instance, the Sainsbury's just off J25 M5 @ Taunton and surely there has to be a Supermarket just off the M4 twixt Bristol and London.[/QUOTE
ASDA Reading West
Bertie Bassett
2,743
8,702
since 1988
Sainsburys but you have to go down the M32 a bit to get to it. Diesel was 1.32 a litre two weeks ago.
jollyrodger
6,282
26,426
Devon/Cornwall
'Obby
Since 1968'ish
Needs an update for sure lots of missing fuel/store stops .bet the one on the app are costa ;) packet coffee stops
scotjimland
2,396
10,479
A Woosh bang
Contact the author by leaving a comment on the map.. the comment button is under the map description ...
alternatively , start from scratch, generate a new map using the existing POIs as a start.. you could also share the work by having a named collaborator.. or even leave it 'open collaboration', but you run the risk of bad info being added .. this will be the reason the the author of the existing map has kept it 'closed'
19,789
23,084
Hertfordshire
Van Conversion
40 years
I've had Asda and other supermarkets installed as POIs for a number of years even got Asda theme tune which comes up with it. Other supermarkets are available but they are only competitive if there is an Asda close by. The theme tune brings a smile to the faces of passengers anyway.
May 5, 2014
671
169
Leicestershire
Beginners, got Doggy the van - March 2014
This map missing lots of information.
M1J21 two Supermarkets (Asda & Sainsbury) in 3 min distance.
scotjimland
2,396
10,479
A Woosh bang
Contact the author by leaving a comment on the map.. the comment button is under the map description ... or make a new map of your own .. but it's a thankless task making Google maps and no matter how good, it's never complete..
Reactions: GJH
