habitation check (1 Viewer)
GrahamCardiff
155
55
Cardiff
PVC Sunlight Cliff
Since 2018
Hi,
Does anyone have any information about habitation checks for a Sunlight Cliff PVC? Should it be annual or every couple of years? Thanks!
Vanman
1,671
3,926
Runcorn
Roadscout R PVC
March 2017
It usually depends more on a manufacturers or dealers warrantee. If it's out of warrantee then it's entirely your call - based on usage and age usually. If you have gas then your best getting the boiler checked every year, some places will do a gas and leccy check for much less than a full hab one (especially as PVC are less damp susceptible).
GrahamCardiff
GrahamCardiff
155
55
Cardiff
PVC Sunlight Cliff
Since 2018
Thanks - yes I was told a PVC doesn’t need a water ingress check .
GrahamCardiff
GrahamCardiff
155
55
Cardiff
PVC Sunlight Cliff
Since 2018
Yes, the manufacturer confirmed that no water ingress check is needed.
GrahamCardiff
GrahamCardiff
155
55
Cardiff
PVC Sunlight Cliff
Since 2018
Here’s what Sunlight said . Could still be worth a check though.
Sapper520
2,879
4,506
North Somerset
No longer own one
September 2020
Hi,
Collected our Cliff last September. Dealer said to keep the 5 year warranty valid the Habitation checks should be carried out annually at a Sunlight authorised dealership. (y)
Lenny HB
53,772
151,301
On the coast in West Sussex
Hymer B678 DL
Being a German van I very much doubt it I suggest you check with Sunlight also I expect the warranty is only 2 years. The water ingress warranty will be 5 years and it may need an annual damp check.
Sapper520
2,879
4,506
North Somerset
No longer own one
September 2020
Extended warranty. Base vehicle Fiat 2 years, with Dealer extending (via RAC policy) another 3 years…..probably not worth the paper it’s written on.
Sunlight Habitation Warranty 2 years, Dealer extending it by another 3 years……subject to annual checks being done from new.
Manufacturers 5 year Water ingress warranty. (y)
Abacist
3,811
11,284
Devon
N & B Arto 88F Tag
since 2013
Most Motorhomes and Campervans will have gas appliances, gas cylinders etc. There is a requirement to have an annual check by a qualified Gas Safe Engineer. There is a Health & Safety Executive Code to be followed and if you ever have a fire or gas related accident you will be expected to demonstrate how you have complied with the code which includes an annual gas safety check by a qualified Gas Safe Engineer qualified to check the gas systems and appliances in your van. Legal liability for third party injury and damage and denial of responsibility by your insurers is a probable consequence. I think there are also requirements to have periodic certifications of Electrical installations. I'll leave this here for people to consider.
Lenny HB
53,772
151,301
Hymer B678 DL
That only applies to hire vehicles. The only gas safety check I'm aware of is German registered vehicles have to have a check every two years.
Abacist
3,811
11,284
Devon
N & B Arto 88F Tag
since 2013
The document I read made no mention of only applying to hire vehicles.
Abacist
3,811
11,284
Devon
N & B Arto 88F Tag
since 2013
Lenny HB I owe you an apology! I went back intending to find the regulations and post hem here only to find that they do clearly state that the regs apply to hired/rental vehicles or static or mobile caravans and privately owned ones are specifically excluded!
Jan 23, 2016
1,908
307,384
Wales
Adria Coral 660SP
25 years
Sorry if I'm being think but;
To me that reads that there is no warranty, not that checks aren't retired.
Sapper520
2,879
4,506
North Somerset
No longer own one
September 2020
Not sure what you mean….my warranty documents have water ingress cover, along with a whole load of conditions you have to comply with for any of the warranty to be valid.
Water can get in via several areas as the van has had holes cut in the roof and sides. (y)
