Guitar setup (1 Viewer)
eddie
8,180
41,442
Taunton Somerset
RV
since 1989
Has anyone ever been on a course on how to setup or fine tune a guitar?
What would you need to know?
Luckily I have pitch perfect hearing and can tune a guitar perfectly by ear. If not use a pitch fork or a new fangled electronic tuner
old-mo
Extra Special
16,346
93,839
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
ShiftZZ .........
Before I gave all my stuff to a young boy who lives opposite and could not afford a guitar...
I gave him one of these =
Amazon product ASIN B002IRTZWM
Idiot proof and dead easy to set up and tune a guitar...
And NOT expensive.. (y)
He has had my guitar for a couple of months and is getting on well with it..
Coolcats
5,978
10,063
HymerCar Ayres Rock
Everyone will have a different take but this may help
1) Download the fender Guitar Tuner on you phone Apple or Google App store
2) You may want to use structured sessions by joining Fender Play which is a monthly subscription service here is a review
Personally I think this structured program is a good way to start
Jan 11, 2010
2,757
9,628
Chester
Auto-trail
If you have a smart phone download the App "Simply Tuner" will tune Acoustic, Electric, Bass and Ukulele. also shows Chords.
Brilliant App which I use on a daily basis.
Just seen the two above posts, my bet would be find a local Luthier.
Janine
14,388
43,276
A little bit left of Middle England
2006 A/S Nuevo
since 1988
I mean fine tune as in setting the bridge, nut etc, plus the Truss rod, Intonation, fret dressing.
Is the action too high at the moment?
If you are going to file the nut, do it millimeters at a time with specialist files. (Look on ebay for fret files)
Don’t take it too low otherwise it will buzz.
ShiftZZ
ShiftZZ
21,386
85,010
Dark Side of the Moon
That's the problem, Intonation is off, I need to be able to sort these things out, I have a Fender strat, but I don't want to screw that up. Just thought it would be a good thing to learn..
Mar 30, 2022
1,495
1,424
Swift Suntor 590RL
What style bridge does your strat have ?
Intonation is easy to set.
Apr 19, 2019
2,293
4,851
Carado T339
5 years
Take it to a good guitar shop. Its a skilled job and you can make a real mess of it. They do it with their eyes shut and charge surprising not much. I once messed with my strat and I had buzzing frets for weeks. An hour in the shop, sorted
Mar 30, 2022
1,495
1,424
Swift Suntor 590RL
You can't make a mess of setting intonation as you're just adjusting the string length.
If you adjust (file) the nut or adjust string height or neck relief, then you could get fret buzz, choking etc.
Mar 30, 2022
1,495
1,424
Swift Suntor 590RL
Seriously if it's just intonation a luthier is not needed.
If intonation is sharp lengthen the string if it's flat shorten the string, using the bridge string adjustment screws.
Mar 30, 2022
1,495
1,424
Swift Suntor 590RL
You can play any style on any guitar.
I don't really shred, mainly classic rock, metal and blues.
Aug 19, 2013
2,974
4,313
Wells, Somerset
Elddis 115
since 2004
My eldest son Gary is in the process of opening a guitar shop in Mont de Marsan, France. He offers a guitar servicing and dressing service. Not much help here, but if anyone is on their way to Spain, it's roughly en route!! I was seriously wondering if there was much call for his skills in the middle of France since I'd never heard of the facility, so perhaps it'll work for him!
makems
3,440
27,752
Ingleby Barwick,,Teesside
Sadly had to give up
If intonation is off this can all be adjusted quite simply and you won’t screw anything up that isn’t easily reversed.
you need to-learn this because if you ever change string height (also easy) or change to a different guage of stings eg from 9s to 10s then the intonation will need to be adjusted.
Assuming you have string height as low as you like it (always adjust this first using the vertical screws on the bridge saddles), then using a clip on digital tuner play an open string and ensure it is exactly in tune. Next play the same string at the 12th fret. If the intonation is correct it should be the same note one octave higher and perfectly in tune. If it isn’t in tune do the following:
If the fretted 12th fret note is sharp, adjusting the horizontal screw at the back of the bridge clockwise will improve intonation. Give it a half turn, re-tune the open string and check the fretted 12fret note again.
If the fretted 12th fret note is flat, adjusting the screw clockwise will improve intonation.
Things like truss rod adjustment and especially nut slot adjustment are definitely in the ”advanced” category and should not be attempted without having the correct tools and either some training or a great deal of confidence.
Fret levelling and crowning require skill and specialist tools.
for years I have done my own string height and intonation adjustment - I learnt by trial and error more than 50 years ago. If I need any other adjustments I take my guitars to a proper luthier - they are all expensive instruments that I use on stage and I can’t afford to ruin them.
while it would be interesting to know how to carry out the specialist adjustments, I really wouldn’t get to use those skills more than a couple of times a year (I have half a dozen guitars but hardly ever change string guage) so it wouldn’t be worth the cost. my luthier will do a fret level and crown, adjust nut, string height and intonation for £75 (£85 for my 12 string).
courses seem to range from £120 to £200 then there are the tools required £100 for Chinese stuff up to £300 for pro level tools.
hope that helps
