Grey water/fresh water (1 Viewer)
Jun 4, 2022
Swift lifestyle 620
Hi folks. Just bought a 2000 lifestyle 620. Can't find how to empty both the waste and fresh water. I've read on another forum for the fresh water there might be a plug inside the tank? Cannot see any plug under motorhome for the waste. Could it be like a caravan and empties all the time? Or should it go into a tank?
Mark and Mindy
1,031
4,814
Nr Bicester
Adria Twin 640 SGX
Since 2019
Just taking generally for both of our vans which were different make and model to yours...
The fresh water drained by turning a tap above the tank which opened a drain underneath.
The grey water drained by turning a tap outside under the van.
Someone will be along with the correct answer for your van soon.
RowleyBirkinQC
2,351
228,214
Dazed & Confused
We once had a 2003 Swift Lifestyle 590 RL, the fresh water tank on that definitely had an internal plug which had to be removed from inside the fresh water tank (through the top of the tank, remove the round screw on cover to reveal access hole) in order to drain it. The grey water tank was drained via a tap on the external grey waste pipe.
