Grey waste tap (1 Viewer)
Jan 5, 2020
141
145
Van
15 yrs
Swift Sundance 2012 has usual grey plastic tap for emptying waste.
This is incredibly slow and embarrassing on-site when there are people waiting behind me. I'm sure someone recommended a different type of tap that is much quicker to empty but cannot seem to find it now. It was bit like something you would get from a plumbers merchant. Any ideas please?
Also the tank never seems to completely empty. Even when the tap stops dribbling there is still quite a bit of water in the tank. Do you think I should lower the outlet pipe a bit so it runs down from the tank to the tap end. At the moment it is pretty level.
Thanks folks!
Two on Tour
10,398
51,524
Elddis Autoquest 175
Since 2010
Here's how I improved the our grey waste dumping problem on our Elddis.
Dumping our grey water has been a source of embarrassment on more then one occasion with other motorhomes queuing up, drumming their fingers waiting for the paltry flow from our grey waste to finish.
I purchased from CAK Tanks a 28mm grey waste drain tap and a 28mm to 25mm pipe reducer.
The tap - https://leisurelines.net/28mm-grey-waste-water-drain-tap-valve-4303-p.asp and the reducer - https://leisurelines.net/28mm-grey-waste-push-fit-male-pipe---25mm-hose-adaptor-j-433-p.asp
A simple job on our Elddis Autoquest 175. Remover the offending original grey waste drain tap, remover the rubber grommet on the tap mounting bracket.
The new tap is a nice tight fit into the mounting bracket and I used a jubilee clip to secure it in place, reconnect the hose from the grey tank and job done.
I can now soak ever bodies shoes at 20 paces. :LOL:
The old tap = 18mm inlet and 14mm outlet
New tap = 23mm inlet and 28mm outlet
Inlets
Outlets
I nibbles a bit out of the mounting bracket to help lock the tap outlet to the bracket.
Cheshirecat57
3,482
5,590
Mid Cheshire
None
10 years on and off
Inlets
Outlets
Based on Two on Tour recommendation above, i did this and it works a treat
Jan 19, 2014
9,402
24,807
Derbyshire
Elddis Accordo 105
since 2014
Our tap is the elddis one pictured above, it's gone really stiff lately, does it come to bits so I can grease it?
Apr 20, 2020
1,083
2,373
Northern Ireland.
Adria Compact SC.
Since 2017
You may find that the hole in the bracket is not big enough for the new tap.
Our Elddis is a 2019 model and the bracket is not a nice stainless steel one like the one pictured above.
It appears to be mild steel painted black and has already started to rust!
You can make the hole bigger or alternatively do what I did which was to cut a small amount off the end of the new grey waste tap.
You need to cut just behind the second flange where the waste pipe attaches.
This makes the diameter of the tap smaller which will then fit through the existing hole.
There will also be a baffle fitted inside the outlet on the new tap which you will need to remove - it is a tight fit but just pulls out.
I didn't realize it was there and wondered why the flow was no better.
Jan 19, 2014
9,402
24,807
Derbyshire
Elddis Accordo 105
since 2014
rperham
Elddis Evolution 196
Hi guys
My first post so any tips amazing.
ive recently brought my 2019 Elddis Autoquest 196. It’s almost new with only 2000 miles. I recently drove it on the motorway and the grey waste bracket ripped off and took the waste tap with it. Luckily it left the plastic pipe.
Upon further inspection the clean water tap is rubbish with little drain and bracket is also in bad condition and loose. it’s black and rusting. The pipe is also only 12mm.
any advise on best setup and where I can get new brackets?
Apr 28, 2021
150
309
Fareham, UK
Now sold
Since 2015
As an ex WE tiff, I feel sure that you have had ample experience in hacking things to bits :giggler:
Paid your bunk light bill yet? I understand the gov’t are chasing up outstanding bills!
I carried out the modification to the waste pipe and it works a treat (y)
Nov 19, 2019
793
2,605
Challenger 287GA
Since 2020
I bit many times as a baby tiff, however the bunklight bill wasn't one of them. I did once get an Ensign to go round 2 deck on HMS Cumberland recharging the emergency exit, glow in the dark floor stickers though!
Apr 28, 2021
150
309
Fareham, UK
Now sold
Since 2015
Hi guys
Just carry out the mod suggested by Two on Tour, it works a treat. A blue tap should be fairly easy to source from the same link. Bracket is just a piece of thin steel plate with a couple of suitable holes and then bent to shape. A cardboard template will easily give you the correct shape.
Two on Tour
10,398
51,524
Since 2010
One thing I forgot to mention in my original post was that there is a baffle covering half the diameter of the outlet on in the drain tap, and I think it was 25mm holesaw that I ran down the drain tap outlet to remove the baffle to stop the baffle restricting the flow.
Sep 9, 2019
876
1,926
Runcorn
Autotrail Apache 632
Since Sept 2019
These all look fab and seem to work well but I’m a little concerned about ground clearance issues and potential contact with slumbering plod! :ROFLMAO::ROFLMAO:
Apr 28, 2021
150
309
Fareham, UK
Now sold
Since 2015
That baffle just pulls out, its an insert into the outlet end of the tap (y)
Aug 6, 2013
11,959
16,575
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
These never clog and don't stiffen with age. They're available in all sizes.
<Broken link removed>
Apr 28, 2021
150
309
Fareham, UK
Now sold
Since 2015
They must have change them then as mine was moulded in as the can see in the photo the line halfway down the outlet where I cut mine out.
Could well have done because mine was on back order for a week or so.
Dec 31, 2021
136
218
Somerset, UK
2022 Chausson 660
Previously Elddis Accordo 125
Many thanks for this! I've just ordered the parts following your links for my Accordo 125
Mar 22, 2018
57
149
Cumbria
Bessacarr E442
Since 2016
Like many others I got a bit tired of waiting for the grey water tank to empty so have fitted a 40mm pipe with full bore valve. The flange is mounted on the underside of the tank so no lip inside. It is obviously lower than the original outlet but still well above the rear axle so unlikely to get knocked.
Away next week so proper test then!
Attachments​
Apr 27, 2008
11,851
14,093
Eastbourne East Sussex
Hymer low profile
Since 1972
The only mh I had with a useless grey water outlet was a Swift. I think it must be a British thing as all my continental ones have had a proper 40mm drain.
Dec 31, 2021
136
218
Somerset, UK
2022 Chausson 660
The Grey Tap Baffle Mystery
I have just received my grey tap and looked at the two offset baffles inside the outlet. They didn't look removable but in a lightbulb moment I slid a knife between the two baffles and turned it. The baffle unit easily rotated and slid out.
Screenshot_20220518_143901_com.android.gallery3d.jpgScreenshot_20220518_144336_com.android.gallery3d.jpg
Wannabee
133
130
Halifax
CompassAvantgarde196
30 years on boats now MH now a chugger
Hi guys
I've had exactly the same problem on the same van. Mine came off the fitting under the tank leaving it hanging so I bonded and jubilee clipped it back on and made a new stainless bracket that gripped the tap and prevented the whole twisting force being transferred to the tank which was the cause. Replaced the tap as well as it had gone all stiff and horrible. Sorted.
Cohen's Campers
RT 707
Inlets
Outlets
Can you please tell me where you got the mounting kit for the tap? Thank you
