Globescout soft close adjustment (1 Viewer)
davem1
3
Globecar globescout
I have a Globecar Roadscout 2019, when I close the siding door and the close close mechanism kicks in it closes the door nice and flush, when it releases slightly at the end of its operation it leaves the bottom of the door slightly proud by about 5mm, can this be adjusted.
I look forward to your reply’s.
Many thanks
Jun 12, 2016
1,623
4,361
Scottish Borders
Globecar Revolution
Since 2006
There are adjustment screws on the motor or atleast there are on our 2015 van
Accessed by removing one of the drawers
I would check the fixing on the motor that pulls the door in is not working loose first
I cant remember which screw to adjust there are instructions somewhere on the German Possl forum
Jun 12, 2020
467
1,331
Scotland
Carthago 138 Compact
Since 2017
The door catches on the sliding door can be adjusted. These are the plastic bits that slide into the holes on the door surround on the main cab body. They have torx bolts, just loosen the bottom one and move it a bit. Give them a bit of silicone grease on the plastic bits that slide together as well. Stops them from creaking when the door closes or when driving.
