Gaslow and Calor Gas together (1 Viewer)
Peterd
37
23
Adria Twin
Newbie
I have a 2008 Adria Twin with 2 bottles, one large Gaslow and one red Calor Gas. They are linked but I am not sure what to do as the Calor Gas bottle doesn't have 'Propane' written on it. The Gaslow bottle is refillable but what about the Calor Gas bottle. There is external fill up connector
Can anyone help please. I have looked on YouTube but have not found the answer to this problem
Jul 6, 2009
1,853
2,310
The gas low is designed to be filled by a lpg pump, it has a cut off valve which prevents overfilling. The red propane calor bottle should only be exchanged for a full one at a supplier. Do not under any circumstances attempt to have the Calor one refilled. The gas low valve shuts it off at 80% capacity preventing liquid from entering the gas supply to the van. The Calor doesn’t and could cause fire or explosions. You will know doub’t get all the clever smart people who will tell you you can refill it in spite of the fact it’s illegal.
Peterd
Peterd
37
23
Adria Twin
Newbie
Many thanks. I now know the answer which is of course the one you have given.
Lenny HB
54,260
153,465
On the coast in West Sussex
Hymer B678 DL
The external fill will only connect to the Gaslow bottle, the Calor is only there for a backup if the Gaslow runs out.
If you are a heavy gas user it would be worth fitting a second refillable.
Peterd
Peterd
37
23
Adria Twin
Newbie
I will not be attempting to fill the Calor Gas, preferring to take the if in doubt route
Peterd
Peterd
37
23
Adria Twin
Newbie
Is it easy to add another Gaslow bottle? Should I get a professional to do it if I can source a reasonable 6kg second hand bottle
Lenny HB
54,260
153,465
Hymer B678 DL
If you can use a spanner it's easy, just make sure you check for leaks after the install. you can use an aerosol spray leak checker or a gas sniffer.
I always carry a Honeywell EZ sense sniffer.
Amazon product ASIN B008ASXV8W
Peterd
Peterd
37
23
Adria Twin
Newbie
Can I add a Gas It tank instead of a Gaslow as I see they are said to be refillable propane?
TheBig1
17,672
43,583
gas-it, gaslow or alugas, all can be connected alongside each other without issues
Peterd
Peterd
37
23
Adria Twin
Newbie
Many thanks to you all. Used Gaslow bottles appear to be much more expensive than Gas It so needed to ask.
Sep 3, 2012
7,646
26,303
Cheshire
C Class Elddis 175
8+ years
The "red calor" bottle you have, I don't suppose it's a gasit bottle? Does it definitely state "calor", on the bottle?
Feb 27, 2020
392
709
pilote diamond 783
2 years
This is what I am doing, presently one gaslow and one standard bottle addit a gassit once i get back to the uk to collect.
Feb 27, 2020
392
709
pilote diamond 783
2 years
Jul 6, 2009
1,853
2,310
Unless you are a heavy user just use the refillable when it runs out switch to calor, fill the tank switch back again. Then when you are nearly at the end of that particular break run the calor down so you start off with a full one next time.
Sep 3, 2012
7,646
26,303
Cheshire
C Class Elddis 175
8+ years
We have just returned from a 10 night stopover, off grid. We have good solar, but need gas for fridge, cooking etc, we have an oven which we use. As the weather has been good, we used no heating. We have 2x 6kg gaslow and filled up just before our 10 days. Refilled and took 11 litres. So on average just over 1 litre a day. The second tank was turned off. The gauge was just showing red when we turned the gas off to leave. Your larger tank should be OK for at least 15 days, with some hot water and some heating. As has been said use the calor as a back up, and top up the gaslow after each stopover of a few days. Chances are you may never use the calor. But a good back up. (y)
Oct 12, 2009
10,883
24,100
A Class N+B Arto 69GL
Since 2009
If this is of any interest for those with the old propane 37Mb regulators.
I inherited a MH with a 37Mb regulator which will screw directly onto my Gaslow and the Calor propane. So changeover is easy, but with a 11kg Gaslow in 11 years we have never had to revert to the Calor back-up.
SUPPLEMENTARY TOPIC
Are 37Mb regulators still available? I ask as I do not have a spare and if mine failed it would be a faff to install a 30Mb bulkhead and attendant supplemantary pipes.
If they are available sources for them would be appreciated.
Thanks in advance
Geoff
Peterd
Peterd
37
23
Adria Twin
Newbie
Just bought a refillable 11kg bottle and need to add it to existing set up after removing Calor Gas propane bottle. Anyone know of a good YouTube "how to" video or one on this site that shows clearly how to connect the new tank? I think I will need a new pipe and connector/s and obviously need to be sure.
2x2camper
851
2,006
You could just use a POL adapter to connect it. Thats all I use
dodfloss
211
520
beverley yorkshire
dethleffs eighty a class
2 years
Just in the process of buying new adria twin, salesman said best to have gaslow, my question it is a £1000 extra to fit or can have one gaslow and one swap a bottle can you have the two on the switch over , with having to go outside when one is empty. Thanks for any help in advance, I’m a total techno phone on these matters
