Gas on ferry at Plymouth (4 Viewers)
ShiftZZ
21,386
84,988
Dark Side of the Moon
Interesting discussion on the Carthago Facebook page.
1st post.
Hi gang! We are just about to board the ferry at Plymouth and just thinking to myself, if I switch the inverter on, would the fridge work off the leisure battery?
A reply.
Would need to be wired to run off mains. But could be 15A an hour.
Then.
Thoughts?
We always store little in the fridge, but we do freeze bottles of water to keep the fridge cold..
53,823
151,596
Against maritime regulations to have an open flame on a car deck. Only an idiot would do it.
I really think ferry operators should be more diligent about vehicles with gas appliances.
Apart from the tunnel Newhaven is the only port I been to that checks.
Anyone who runs there fridge on gas on a ferry should be banned for life from ferries.
Dec 2, 2019
4,139
9,297
South Lincolnshire
Rapido 7065+
Broken most bits now
I bet there's quite a few that don't even realise that they have left the fridge running. After 15 mins many AES fridges will try to fire up the gas even if it's turned off at the bottles. There may not be a naked flame but the spark will keep trying to ignite it anyway which is just as dangerous. How many people actually know how to turn off their moho fridge?
2,429
10,625
I must confess...
Our USRV did not have 12v option on the fridge, (most USRVs do not ) and ran on gas while travelling .. as it's designed to do .. but I forgot to switch off before boarding a ferry,,
No excuses.. the LPG should have been isolated
On other occasions I've seen a crew member feeling fridge gas vents to no doubt see if they are on gas or not
Jul 18, 2009
11,268
18,178
HYMER B644
11,268
18,178
HYMER B644
Deck Crew should go around checking 30 mins after loading.
An ear or a hand to a Motorhome, camper, caravan fridge vent is an easy way of telling.
Emmit
8,061
17,819
Pilote Explorateur
Jan.2014
Just a thought but I don't ever recall there being a fire on a cross channel ferry car deck.
Partially right. However, Ferries ply all over the World.
May I direct you to a search; MS Norman Atlantic
Nuff said.
Aug 18, 2014
23,905
135,017
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Thoughts?
Yes Bryan Chalice & Norman Rogers should be shot with a bolt gun
We haven't used a ferry for years, we take the tunnel because of our dogs. This is another reason to avoid a ferry.
& what is the difference on the tunnel? Nothing if the ****s leave it on on a ferry the same they would do on the train & just as dangerous.
& the tunnel & then shot.
Apr 27, 2016
6,903
8,045
Manchester
A class Hymer
Since the 80s
It certainly could in theory, I always run our fridge from the inverter on a ferry. However most inverters are wired so that the fridge is not powered from the inverter.
The problem is that as you say it takes a lot of power. About 15A, so it would use about 15Ah every hour. That's a bit pessimistic, because it's on a thermostat so would switch off for a lot of the time. Especially if it was already very cold and the door wasn't opened. You could turn the thermostat up so the fridge was keeping a higher temperature, it would take marginally less power.
Before I got the inverter and 600Ah of lithium, I ran the fridge off 12V, from 4 x 100Ah 12V lead-acids, and it just about lasted to Santander.
Jun 29, 2015
3,502
57,950
Southampton
caravan (for now)
on and off since 1984
A fire in the tunnel is less dangerous than on a ferry. Each compartment can be sealed and the fire contained, if that fails there is an escape tunnel next to the main tunnel
bigtwin
5,272
10,007
Derby
Concorde
Now let me see, 🤔 that might just be because application of the existing regulations prevents it! However, a risk remains because of those who think that they know better.
If only ships had gas dropout vents in the bottom of their hulls then we could all leave our gas fridges on.đź‘Ť
Ian
Aug 18, 2011
12,163
18,035
derbys
AUTOSLEEPER SYMBOL
They usually physically check your gas is off when using the tunnel.
x17ken
179
433
Wales
Bailey Adamo
We crossed from UK to Santander 8 weeks ago. The guy on the port of departure said turn off your gas. I said of course. But he didn't believe me. He said, I must see you do it before you get any closer to the ship. I had to show him the closed valve before he would let me move. This was good and responsible.
I have a few further observations on this debate:
Why do people think they need to keep their freezers/fridges on for short crossings? Goods will not spoil for a few hours if you keep appliances closed and off.
For longer crossings, why not travel empty and stock up when you get to France, Spain etc?. Their supermarket choices are superb and cheap. Why not enjoy the local choices from the get-go? There is no need to take UK chilled/frozen foodstuffs with you. You will run out at some point in your holiday and will need to use the local choices.
I do accept that there may be medical reasons for constant refrigeration of goods in some cases. These cases require bespoke solutions. Leaving unsupervised gas appliances running in a dangerous environment is probably not the best option.
I pose these questions for reasons of passenger safety and protection from accidental ignition of explosive emissions on international transit vehicles.
Aug 18, 2011
12,163
18,035
derbys
AUTOSLEEPER SYMBOL
Things don't spoil on long crossings providing fridge was cold before it was switched off.My beer is still cold after 30 hrs on Spanish crossing. BUSBY.
Oct 30, 2016
1,461
2,881
Colchester
Le voyageur 8.5
On 3rd van so not a total newbie....
What's the benefit of running through the inverter if it will run on 12v? Surely it will use the same power, but just incur inverter losses?
We put ours on 12v on ferries on the basis that any power taken from the battery will be replenished from the drive when we get there.
Apr 9, 2018
8,729
45,408
Worcestershire
Bailey Adamo 75-4t
March 2018
But, does your fridge only run on 12v hab battery when the engine is running?
x17ken
179
433
Wales
Bailey Adamo
Chuck a couple of supermarket ice bags on top of the beers in the bottom of your fridge before you leave, keep the door shut, and you will have complete satisfaction on your arrival no matter how hot it is :cool:
Apr 9, 2018
8,729
45,408
Worcestershire
Bailey Adamo 75-4t
March 2018
Thought it ran on power from alternator when engine is running..not leisure battery. BUSBY
Maybe you are right, but if it is wired to the hab battery that won’t last long running a fridge, unless serious mah.
