Kannon Fodda
- Feb 26, 2019
- 2,636
- 8,118
- Autotrail V-line 540
- I Make Schoolboy Errors!
Underslung 25litre cylinder type Gas-It with in cab 9 LED Gas-It level display, All factory fitted by Autotrail.
The gauge is way way out. With 2 LEDs lit, expecting to be nearly empty, I could just squeeze in a tad over 8 litres of LPG. I know the tanks can only be filled to 80% capacity, but that is way out. Thinking about it, I've never been able to get much in. Only conclusion the gauge is reading wrong.
Are gas gauges a useless toy, or is there something wrong that I, or someone else should be adjusting? Is it possible the tank has been poorly mounted?
Oh and before someone says it, the water tank drain hoses aren't supported.
