Gas hob igniter (1 Viewer)
Bonkers the Dog
372
944
Ayrshire
Pilote Explorateur
2 yrs
Hi,
Mine has gone u/s.
I tried to fix it but even getting to it is a PITA and I quickly lost the will to live.
Is there a trick to getting these things out without dismantling the kitchen?
I am guessing it is a pizo-electric sparker. Can they be serviced/repaired or is it fail and replace?
Cheers in advance folks
BTD
Jun 29, 2015
3,531
58,620
Southampton
caravan (for now)
on and off since 1984
Not likely to be a pizo these days, more likely to be a 12 volt ignition generator. So check electric supply, push switch and it's also possible it is battery operated, so look for a battery carrier.
It would help if you said whitch model and if you can a picture
Bonkers the Dog
Bonkers the Dog
372
944
Ayrshire
Pilote Explorateur
2 yrs
Did that, then the drawers, then the door, then the internal braces and I still couldn't reach the bu**er, I then went and bought a swan neck lighter for a quid; it's still going!
This was the issue though, I was having to dig deeper and deeper just to change the thing out; life is too short but SWMBO keeps asking me about it so I thought I better revisit it...
Apr 27, 2016
6,974
8,150
Manchester
A class Hymer
Since the 80s
A piezo-electric sparker has a button which has a definite travel distance, and a loud click at the end of the travel. If you want another spark you have to press it again.
An electric spark generator has a push switch that generates a stream of sparks for as long as the switch is pressed.
