Fuel gauge goes off (1 Viewer)
BBC
Jul 31, 2021
6
9
Lowestoft, UK
Majestic196
8 years
Hi just wondered if any other Ducato base have had this problem?
Whilst driving along the fuel gauge goes off along with the indicator sound.
I took it the dealer & they updated the software with fixed the flashing odometer but not this problem. Comes and goes within 10 minutes of driving.
Any ideas
Mar 26, 2018
440
1,366
Ormskilrk
Swift Voyager 685FB
On my slightly older Ducato the fuel tank sender is under a removable cover next to the passenger seat. It might be worth checking the connector as if that come lose you lose the fuel gauge.
TheBig1
17,662
43,545
Sounds like a poor earth feeding the binnacle. It works when cold but the bad connection heats up and it switches off till next time it gets turned on
Apr 22, 2018
6,843
12,620
Herts.
Adria Coral lowline
Some have had it where the wires have been damaged under the hatch between seats whilst people have been walking back and forth across the area.
May 14, 2021
1,756
2,818
East Yorkshire, UK
ADRIA Twin 640SLB
Since 2012
I have a similar issue, my 22 Ducato has worked fine since July 22. Then I noted the gauge was around 1/4 so filled up.
I did put in 78L which I was surprised at as I also thought my tank was only 70L not the 90 one.
The gauge read nothing after I filled it and it said ‘Fuel level unavailable’ Then it still would not come back on but after a journey of 80 miles when I switched the ignition off and back on again it showed the tank full. I drove the 80 miles home and it is still showing full and I must have used 30L after about 190 miles total.
Anyone had this problem too before I arrange to take it to a FP garage under the warranty.
