Fresh water tank ventilation (1 Viewer)
DrunkenDuncan
37
13
Brize Norton
Pilote G600L
Not enough!
Just fitted a filter on our G600L for drinking water and came across an issue that may or may not pose a problem when filling the fresh water tank with one of these:
On inspection (and discussion with dealer) I established that the tank was vented from a pipe from the top of the tank to the top of the filler here:
Now the issue I have is that when filling with the adaptor, the pressure in the tank was so great that there was water and air being forced out of the water level sensor on top of the tank until I released the pressure by opening the inspection cap (which was considerable; making me wonder about the ventilation of the tank in the first place)
I had of course assumed that the tank would be vented and that filling with an adaptor designed for the job would not be a problem, but it appears that the adaptor seals the filler recess (as does the lockable cap when it is on) so it would appear that the tank is not actually vented at all when either of these are used.
Am I missing something here or is this is by design and I need to fill up the old fashioned way by sticking the pipe down the filler neck so that the air replaced by the water going in can come out past the pipe?
Feb 9, 2008
4,117
5,971
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
My tank vents through an overflow fitted direct from the tank top. I use a watering can to top up though so venting isn't a problem. Does your tank not have an overflow?
Nov 4, 2011
6,039
40,655
Uk
That filler should have come with two seals, one for vent tanks and one for unvented tanks, this one has castlations so it can breath.
I also fitted a piece of pipe to mine to stop water coming out of filler.
Feb 9, 2008
4,117
5,971
SW Scotland
LP Coachbuilt
On the rare occasion I have filled my tank it overflows under the van, not from the filler. There is a proper overflow arrangement. The waste tank has a series of holes drilled in its sides just below the tank top as an overly.
DrunkenDuncan
DrunkenDuncan
37
13
Brize Norton
Pilote G600L
Not enough!
I would say having that breather the filler IS the overflow.
Once full via a hose etc water will simply emerge from the full neck.
Seems reasonable as the overflow pipe (attached to the red connector near the very top of the tank on the side) is the one connected to the vent hole on the filler.
Nov 4, 2011
6,039
40,655
Uk
Only came like this:
Guess I could attach a tube to it like yours and drill a hole in the seal to let it vent - what could possibly go wrong!! :p
Looking at yours maybe not so easy to attach a pipe, mine has a spigot on the back that’s just the size of hose pipe. Mines a Heos filler.
TheBig1
17,672
43,584
there are vented and non vented filler caps available, the one you have appears to be non vented
Aug 18, 2014
24,006
136,381
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
With that type filler assembly the Op's picture shows the vent .It vents from tank top back in to filler neck
The tank must be vented some way whilst the standard cap is on, otherwise you would not be able to get water out of the tank.
It does the actual cap allows air in to the vent pipe.
To the op why do you need the fancy filler cap to fill ? I just poke the hose down exactly the same type of filler & fill at whatever the potable water pressure is & which is usually around the 90-100psi.
Apr 22, 2018
6,858
12,641
Herts.
Adria Coral lowline
That is my point about their statement “it appears that the adaptor seals the filler recess (as does the lockable cap when it is on) so it would appear that the tank is not actually vented at all when either of these are used.”
DBK
18,102
48,484
Plympton, Devon
PVC, Murvi Morocco
Ours has a similar vent in the neck but the lockable cap doesn't block it. You can tell this when you drain the water tank and hear the air rushing in around the cap.
Have no problem with a Heos filler.
