Fresh water system cleaning (1 Viewer)
Zoobec
670
2,458
Peugeot Boxer PVC
Newbie
I drained ours down at the end of the summer and would like to use something to clean it with, I read about putting something in the tank with a small amount of water and leaving it to slosh around before flushing through but I can’t remember what it was!
Does anyone have any recommendations please? Thankyou!
Apr 9, 2018
8,712
45,233
Worcestershire
Bailey Adamo 75-4t
March 2018
hja
May 8, 2020
963
3,186
Lincolnshire
Globecar Summit Prim
Since 2019
We use puriclean every year. Part fill tank with fresh water, pump on, open taps etc to get air out. Dissolve correct amount of puriclean for tank size in warm water, add to tank, fill up with fresh. Open taps to ensure sterilising liquid get into boiler and pipes. Leave overnight. Empty. Refill with fresh. Empty. Good to go.
Mar 28, 2010
197
357
Wirral
A class Hymer 504
Since 1995
It's a good idea slosh around water in your waste water tank.There's a number of chemicals to put into the waste tank at the same time. Drive around a bit and then drain.
I fill our 'fresh' water tank to the brim with clean water and appropriate Puriclean powder - instructions on the carton.
Apr 19, 2019
2,293
4,851
Carado T339
5 years
This has been discussed many times on various threads. I'll repeat the advice I always give. 5mls of Milton into an empty tank. Fill to about 10% with water. Leave 24 hours to stand. Then fill tank, flush though taps. No need to drain or rinse. You are good to go.
It's the method just about every water company in the UK (and isle of man) uses to disinfect water service reservoirs.
Don't waste your money on other disinfecting agents. 5 MLS of Milton will cost you about 10p.
If you want to save the 10p don't bother at all. It's not needed normally. 👍👍
Nov 3, 2020
1,297
2,218
Up the Hamble
Ace Siena
Since 2019
Aqua Sol and follow the instructions on the bottle. https://www.ebay.co.uk/itm/28571156...pid=5339023013&customid=&toolid=10001&mkevt=1
Apr 9, 2022
413
397
Cathargo
Newbie
Thanks for your advice - can I just confirm it is ok with stainless boilers etc at this concentration?
Zoobec
Zoobec
670
2,458
Peugeot Boxer PVC
Newbie
Thankyou everyone for your advice 👍
Apr 9, 2018
8,712
45,233
Worcestershire
Bailey Adamo 75-4t
March 2018
Oh dear. I have never cleaned our tank or pipes!
Does the chlorine in the water not kill any bacteria?
In reality it does. But, if I leave water in the tank for any length of time I feel better with an additive in the water. Maybe a waste of money, maybe not. This goes way back when we had a boat and stored water for a fair while.
However, this did happen in Spain so I had to find some purification solution. Since we have been back I have not had to use the shower so can’t say whether there is any real difference between UK and Spanish drinking water.
If time is not an issue I’m sure an annual clean and use of a storage solution would not be wasted even if it actually does no good. Better safe than sorry.
Apr 19, 2019
2,293
4,851
Carado T339
5 years
At that low concentration. Yes. Absolutely. It's not much stronger than tap water. Neat bleach left for long periods will corrode stainless steel. We are talking about levels of chlorine that is safe to drink.
Apr 19, 2019
2,293
4,851
Carado T339
5 years
By the time water gets to your taps it can be 0.2mg/l or even less. Better to have nearer 1 mg/l to disinfect it if there are bugs in there .
Apr 19, 2019
2,293
4,851
Carado T339
5 years
I wonder. Same chlorine or fluoride levels?
Fluoride? Not sure what that has to do with it. Fluoride does not effect disinfection, taste or odour in any way.
Chlorine levels do vary around the world. In the states they don't like it if they can't taste the chlorine and regularly have levels around 1 mg/l. Spain is generally similar to the UK as they adopt the same standards. That is that all customers should get at least 0.2mg/l at the tap.
Nov 19, 2021
874
1,959
Nr Wigan, UK
Rapido A Class
I believe Coke Cola is best for cleaning your waste tank.
Pour a couple of bottles down the drain, drive around for 15mins and then leave overnight before draining off.
