Fitting second leisure battery (1 Viewer)
brian50@imap
Benimar Mileo 202
I have a Benimar Mileo 202 which appears to be prewired for the fitting of a second leisure battery under the driver’s seat. Is it just a case of popping in a second battery, connecting the terminals up and that’s it?
jako999
304
785
Halesowen
Niesmann Bischoff
It must be the same amperage as the standard battery and your charger may be low on charge amperage that’s not a problem it just takes longer to charge remember to connect in parallel.
It’s an easy job just like fitting solar or an inverter dealers like to make it sound hard and charge a load of money
Dec 6, 2011
11,639
25,584
South Wales
Coach built Adria
When you say pre wired, I assume that there are spare wires under the seat which are somehow insulated at the moment.
Tombola
4,866
15,799
Merseyside
Rapido 8094DF
Since 2004
and rememebr the pos load lead to your van goes on one battery and the neg to the other
Dec 30, 2019
359
277
Manchester, UK
Burstner t700
Early 2019
May be an idea to check if 12v dc is there before you connect, may have bare cables at the other end..
Feb 14, 2021
3,679
7,944
Milton Keynes, UK
Burstner Lyseo 727G
19 month year 18000 miles UK, Ireland, France, Spain, Germany, Italy. Campsites and off Grid.
They are connected in parallel but it should be Earth (negative) from van to negative on one battery and the the live from the van to the other battery. Like below.
Feb 14, 2021
3,679
7,944
Milton Keynes, UK
Burstner Lyseo 727G
By the way - is your present battery under the driver seat too? I couldn't fit 2 batteries under my seat. Had to put the 2nd under a different seat behind the driver.
Oct 6, 2021
566
910
PVC
Join the Benimar group on Facebook, they have the details on there. The wiring for the 2nd battery is already there.
