Fiat X290 Cab battery charging (1 Viewer)
May 19, 2020
205
248
Knaus Sun Ti 650 MEG
Since 2020
As per title , any reason not to attach a charger to the jump lead points under the bonnet, would save lifting the carpet and hatch panel to access the battery terminals directly.
gerry mcg
1,650
2,573
Glasgow, Scotland
Globecar 600L Revn
since 2016
No reason not to use under bonnet connections. In many ways this is preferred, as all charging current goes through the ECU.
Many modern cars don't like direct terminal charging / jump starting
Aug 26, 2008
4,771
25,056
B&NES
Van Conversion
since 2007
I use the 10m EHU lead with an adapter to a 230v domestic socket in the garage. Charges the hab and starter batteries.
Each to their own method.
Aug 22, 2007
2,501
32,757
essex
2017 sunlight t69s euro6
since 1999
mine does not it only charges the leisure batteries unfortunatly
denisejoe
5,627
12,084
Warden isle of sheppy
Since 2004
Check the terminals on the battery as I helped a guy who’s van wouldn’t start turned out the positive lead although fully tightened on battery was still loose had to make a bodge to get him going
mikebeaches
5,397
8,616
Bristol
Rapido V68 Van Conversion
Since 2009
I think the charging set-up varies between different types/makes of van.
Our Rapido charges both hab and cab batteries on the hook-up. But our previous van - Chausson - ehu only charged the habitation battery. So used to go under the bonnet, as suggested above, to attach a trickle charger for the cab battery. (y)
Sapper520
2,879
4,506
North Somerset
No longer own one
September 2020
Our Sunlight Cliff charges both Vehicle and Leisure batteries when on EHU. Also, got the Solar set up so it charges both…..when it’s sunny enough.
EHU been on about 18 hours, give it another 6 and that’ll do for a week or so. (y)
